[Tuto] Changer Soufflets de cardan Icon_minitimepar SuperBat Sam 21 Sep - 13:00
[Tuto] Changer Soufflets de cardan Icon_minitimepar COX1303 Jeu 19 Sep - 15:51
[Tuto] Changer Soufflets de cardan Icon_minitimepar le fous des cox Mer 18 Sep - 20:33
[Tuto] Changer Soufflets de cardan Icon_minitimepar bab doé Lun 16 Sep - 21:16
[Tuto] Changer Soufflets de cardan Icon_minitimepar Peck Lun 16 Sep - 20:01
[Tuto] Changer Soufflets de cardan Icon_minitimepar Peck Lun 16 Sep - 19:56
[Tuto] Changer Soufflets de cardan Icon_minitimepar Peck Lun 16 Sep - 19:35
[Tuto] Changer Soufflets de cardan Icon_minitimepar dyonisthor Dim 15 Sep - 23:32
[Tuto] Changer Soufflets de cardan Icon_minitimepar dyonisthor Sam 14 Sep - 16:33
[Tuto] Changer Soufflets de cardan Icon_minitimepar Jul 13-02 Mar 10 Sep - 19:59
[Tuto] Changer Soufflets de cardan Icon_minitimepar Jul 13-02 Mar 10 Sep - 19:56
[Tuto] Changer Soufflets de cardan Icon_minitimepar burgon Mar 10 Sep - 16:27
[Tuto] Changer Soufflets de cardan Icon_minitimepar jasgono Sam 7 Sep - 12:32
[Tuto] Changer Soufflets de cardan Icon_minitimepar burgon Ven 6 Sep - 19:31
[Tuto] Changer Soufflets de cardan Icon_minitimepar suzette94 Dim 1 Sep - 17:24
[Tuto] Changer Soufflets de cardan Icon_minitimepar le fous des cox Dim 1 Sep - 17:15
[Tuto] Changer Soufflets de cardan Icon_minitimepar fufu Dim 1 Sep - 11:16
[Tuto] Changer Soufflets de cardan Icon_minitimepar COX1303 Ven 30 Aoû - 23:51
[Tuto] Changer Soufflets de cardan Icon_minitimepar SuperBat Ven 30 Aoû - 22:31
[Tuto] Changer Soufflets de cardan Icon_minitimepar burgon Ven 30 Aoû - 16:31
zeldacox
zeldacox
Véhicules : 1303/1973
[Tuto] Changer Soufflets de cardan Empty
MessageSujet: [Tuto] Changer Soufflets de cardan   [Tuto] Changer Soufflets de cardan Icon_minitimeMar 24 Fév - 23:11
Slt! Aujourd'hui jai changé mes soufflets de cardan dont je vous met la marche a suivre pour ceux que ça interesse!!
[Tuto] Changer Soufflets de cardan 0011
Premiere étape sortir le cardan: lever,caler et démonter la roue
[Tuto] Changer Soufflets de cardan 0210
Dévisser les 6 vis de fixation de la noix de cardan coté roue et coté boite.
[Tuto] Changer Soufflets de cardan 0310
Sortir le cardan.
[Tuto] Changer Soufflets de cardan 0410
zeldacox
zeldacox
MessageSujet: Re: [Tuto] Changer Soufflets de cardan   [Tuto] Changer Soufflets de cardan Icon_minitimeMar 24 Fév - 23:20
Deuxieme étape sortir le noix de cardan!
Placer le cardan dans l'étau et sortir l'ancien soufflet! Avec un petit burin et un marteau faire sauter
le cerclage!
[Tuto] Changer Soufflets de cardan 0511
Enlever le surplus de graisse et sortir le clips qui est o bout de l'arbre! C'est un peu
galere mais avec rigueur et methode on y arrive!
[Tuto] Changer Soufflets de cardan 0610
[Tuto] Changer Soufflets de cardan 0710
zeldacox
zeldacox
MessageSujet: Re: [Tuto] Changer Soufflets de cardan   [Tuto] Changer Soufflets de cardan Icon_minitimeMar 24 Fév - 23:33
Une fois le clips enlevé, taper legerement sur la noix de cardan pour la sortir de l'arbre!Ne pas oublier de repérer le tout avant de démonter!
[Tuto] Changer Soufflets de cardan 0810
Troisième étape remontage!
Une fois toutes les pieces dégraissées et nettoyées, renfiler le soufflet neuf
et le bourrer de graisse ( spécifique o cardan)!
[Tuto] Changer Soufflets de cardan 0910
zeldacox
zeldacox
MessageSujet: Re: [Tuto] Changer Soufflets de cardan   [Tuto] Changer Soufflets de cardan Icon_minitimeMar 24 Fév - 23:41
Enfiler la petite rondelle , la noix de cardan graissée ( attention au sens du montage) tjrs léger avc le marteau et enfin le clips!
[Tuto] Changer Soufflets de cardan 1010
Et voila soufflet changé prés a etre remonté sur la cox!!
[Tuto] Changer Soufflets de cardan 1110
Quatrième étape: remonter le cardan
Refixer les 6 vis de fixation coté roue et coté boite, serrer le collier du soufflet et remonter la roue
zeldacox
zeldacox
MessageSujet: Re: [Tuto] Changer Soufflets de cardan   [Tuto] Changer Soufflets de cardan Icon_minitimeMar 24 Fév - 23:46
[Tuto] Changer Soufflets de cardan 1210
Voila en esperant que c'est pas trop mal expliqué et que ça servira a quelqu'un!!
BYe..
MessageSujet: Re: [Tuto] Changer Soufflets de cardan   [Tuto] Changer Soufflets de cardan Icon_minitimeMer 25 Fév - 0:31
Super tes explications,tes photos [Tuto] Changer Soufflets de cardan 315149
Pour mes compétences de mécano débutant [Tuto] Changer Soufflets de cardan 55320
Devrait il pas y avoir en plus un post: étapes à suivre [Tuto] Changer Soufflets de cardan 466987
zeldacox
zeldacox
MessageSujet: Re: [Tuto] Changer Soufflets de cardan   [Tuto] Changer Soufflets de cardan Icon_minitimeMer 25 Fév - 15:01
Exacte Jeancox ta derniere étape a été faite en meme temps que le reste! ça donne soif de
faire des photos...
Par contre ce matin jai changé le soufflet coté roue de l'autre coté dla cox, tout va bien bien jusqu'au
remontage du cardan! Impossible de renter la noix de cardan dans son logement coté boite! Bah oui elle est montée a l'envers, Celui qui avait changé le soufflet c legerement planté..Bref tous ça pour dire
de bien faire attention lors du démontage...
Patrick29
Patrick29
Véhicules : 1303 de 1973
MessageSujet: Re: [Tuto] Changer Soufflets de cardan   [Tuto] Changer Soufflets de cardan Icon_minitimeMer 25 Fév - 16:26
Merci pour ces explications et pour les photos [Tuto] Changer Soufflets de cardan 315149 [Tuto] Changer Soufflets de cardan 315149 .
Moi qui débute, c'est le genre d'explications que je recherche!!
Masculin Nombre de messages : 12001
MessageSujet: Re: [Tuto] Changer Soufflets de cardan   [Tuto] Changer Soufflets de cardan Icon_minitimeMer 25 Fév - 16:29
C'est un forum de folie !!!!
[Tuto] Changer Soufflets de cardan Sign1010
[Tuto] Changer Soufflets de cardan Signat10
MessageSujet: Re: [Tuto] Changer Soufflets de cardan   [Tuto] Changer Soufflets de cardan Icon_minitimeMer 25 Fév - 21:58
oui bien sympa se petit post.
MessageSujet: Re: [Tuto] Changer Soufflets de cardan   [Tuto] Changer Soufflets de cardan Icon_minitimeMer 25 Fév - 22:03
Merci Zelda !! [Tuto] Changer Soufflets de cardan 305443
Je l'ai passé en tant que tutoriel ! [Tuto] Changer Soufflets de cardan 315149
Vince.
zeldacox
zeldacox
MessageSujet: Re: [Tuto] Changer Soufflets de cardan   [Tuto] Changer Soufflets de cardan Icon_minitimeMer 25 Fév - 22:12
Merci..
dizu.99
dizu.99
MessageSujet: Re: [Tuto] Changer Soufflets de cardan   [Tuto] Changer Soufflets de cardan Icon_minitimeVen 23 Avr - 10:57
Cool le tuto!!!
J'ai une autre question: Y a t'il un sens pour le remontage des cardans? Différence coté roue ou boite?
Damien
MessageSujet: Re: [Tuto] Changer Soufflets de cardan   [Tuto] Changer Soufflets de cardan Icon_minitimeMar 11 Mai - 17:42
Non pas de sens...
Mais les noix elle oui... Rayure sur l'extérieur...
dizu.99
dizu.99
MessageSujet: Re: [Tuto] Changer Soufflets de cardan   [Tuto] Changer Soufflets de cardan Icon_minitimeMar 11 Mai - 17:58
Okay!!! Merci beaucoup pour l'info!!!
A plus
Damien
MessageSujet: Re: [Tuto] Changer Soufflets de cardan   [Tuto] Changer Soufflets de cardan Icon_minitimeMar 11 Mai - 22:14
Excellent , ce post
Bravo et Merci l'ami [Tuto] Changer Soufflets de cardan 315149
MessageSujet: Re: [Tuto] Changer Soufflets de cardan   [Tuto] Changer Soufflets de cardan Icon_minitimeJeu 23 Fév - 10:39
salut !
super comme tuto !!
j'ai une question: je viens de m'apercevoir que j'ai une petite goutte d'huile de boite (j'ai une 1303 de 74) qui perle au niveau de mon joint "spi": c'est ce changement là que je dois effectuer ??? je comprends mal le rapport entre ces soufflets de cardan et une fuite d'huile de la boite au niveau du cardan...
MessageSujet: Re: [Tuto] Changer Soufflets de cardan   [Tuto] Changer Soufflets de cardan Icon_minitimeJeu 23 Fév - 12:18
Contrairement aux trompettes, il n'y a pas d'huile qui traverse le cardan pour lubrifier les roulements.
Derrière la fixation de la noix de cardan sur la boite se trouve les tulipes de boite.
Au milieu il faudra retirer la pastille. Attention de ne pas la déteriorer, ou en acheter des neufs.
Enlever le clip et enfin la tulipe de boite.
Derrière celles-ci se trouvent un joint spi qui fait l'étanchéité.
Trouvable par exemple ici:
http://www.slideperformance.com/joint-spi-de-tulipe-de-cardan-pour-vw-cox-combi-karmann.html
MessageSujet: Re: [Tuto] Changer Soufflets de cardan   [Tuto] Changer Soufflets de cardan Icon_minitimeJeu 23 Fév - 16:03
wouuaaahhh [Tuto] Changer Soufflets de cardan 315149
merci coxforce !!! [Tuto] Changer Soufflets de cardan 840476
donc, je dépose mon cardan, je retire mon clip, retire la pastille, sors la tulipe et remplace le joint, puis remets tout en place.. en suivant la RAT..
question subsidiaire: est ce que je peux jouer sur l'articulation du cardan pour éviter de le démonter coté roue et ne retirer que les vis à 6pans coté boite ?
MessageSujet: Re: [Tuto] Changer Soufflets de cardan   [Tuto] Changer Soufflets de cardan Icon_minitimeJeu 23 Fév - 16:22
autre question subsidiaire:
chez un autre fournisseur, j'ai ça comme joint spi de srtie de boite à cardan et il semble totalement différent...:
http://www.mecatechnic.com/COX_VS00406_FR_Joint-spi-de-sortie-de-boite-de-vitesses-a-cardans----.htm
je résoud le problème en appelant l'un et l'autre des fournisseurs ??
MessageSujet: Re: [Tuto] Changer Soufflets de cardan   [Tuto] Changer Soufflets de cardan Icon_minitimeJeu 23 Fév - 18:17
D'abord retire la pastille, et ensuite tu retires le clip car celui-ci est derrière.
Aucun problème en ne dévissant que le coté boite.
Attention, quand tu vas retirer la tulipe, tout le liquide de boite va couler.
Donc fais la vidange avant [Tuto] Changer Soufflets de cardan 998756
Chez le fournisseur que tu as mis, c'est le même joint, mais pris en photo de l'autre coté [Tuto] Changer Soufflets de cardan 937163
MessageSujet: Re: [Tuto] Changer Soufflets de cardan   [Tuto] Changer Soufflets de cardan Icon_minitimeJeu 23 Fév - 19:24
[Tuto] Changer Soufflets de cardan 681905 pourtant je n'étais pas blonde avant.... [Tuto] Changer Soufflets de cardan 670322
ok merci pour tout. pour l'ionstant j'ai une goutte ou deux tous les deux jours, alors j'ai commandé pastille et joitn par sécurité.. dans mon garage avec 50cm de large, ça va pas etre du gateau surtout si je n'attends pas qu'il fasse plus chaud pour travailler porte ouverte et avoir la lumière qui entre un peu !!
pour l'huile de boite, j'y ai pensé... je mettrai une bassine en dessous pour receuillir ce qui risque de couler. mais vu je pense que je metttrai quand meme la voiture sur chandelle de ce coté là pour retirer la roue pour avoir accès, alors l'inclinaison devrait limiter le niveau de ce qui coulera, et je referai le niveau une fois la voiture remise sur roue... je viens de faire la vidange de la boite et l'hule est tout fraiche....
MessageSujet: Re: [Tuto] Changer Soufflets de cardan   [Tuto] Changer Soufflets de cardan Icon_minitimeJeu 23 Fév - 20:08
Vidange-la avant, car si tu mets la bassine quand tu veux retirer le joint, l'huile va couler sur toutes les saletés et ensuite seulement tomber dans ta bassine.
Même si tu inclines, crois-moi ça va couler. Car à cet endroit, tu es direct en sortie de différentiel. Ca baigne dans l'huile...
Restocox
Restocox
MessageSujet: Re: [Tuto] Changer Soufflets de cardan   [Tuto] Changer Soufflets de cardan Icon_minitimeJeu 23 Fév - 20:50
Merci à vous ! ca me fait penser que j'ai oublié des les commander ceux la :D
