[Question] Montage Jantes 4 trous - Page 2 Icon_minitimepar le fous des cox Hier à 14:54
[Question] Montage Jantes 4 trous - Page 2 Icon_minitimepar Billocox Hier à 14:43
[Question] Montage Jantes 4 trous - Page 2 Icon_minitimepar Billocox Hier à 14:38
[Question] Montage Jantes 4 trous - Page 2 Icon_minitimepar Sideshowpod Mar 14 Jan - 3:19
[Question] Montage Jantes 4 trous - Page 2 Icon_minitimepar jeromep60 Mer 8 Jan - 21:26
[Question] Montage Jantes 4 trous - Page 2 Icon_minitimepar tintin72 Mar 7 Jan - 20:43
[Question] Montage Jantes 4 trous - Page 2 Icon_minitimepar GUILLAUME Dim 5 Jan - 0:29
[Question] Montage Jantes 4 trous - Page 2 Icon_minitimepar tintin72 Ven 3 Jan - 20:08
[Question] Montage Jantes 4 trous - Page 2 Icon_minitimepar gexmen37 Jeu 2 Jan - 20:49
[Question] Montage Jantes 4 trous - Page 2 Icon_minitimepar snake862006 Lun 30 Déc - 23:09
» Moteur type 4 à refaire
[Question] Montage Jantes 4 trous - Page 2 Icon_minitimepar le fous des cox Sam 28 Déc - 0:17
[Question] Montage Jantes 4 trous - Page 2 Icon_minitimepar le fous des cox Mer 25 Déc - 15:26
» recherche moteur 1300
[Question] Montage Jantes 4 trous - Page 2 Icon_minitimepar tintin72 Mar 24 Déc - 22:13
[Question] Montage Jantes 4 trous - Page 2 Icon_minitimepar le fous des cox Mar 24 Déc - 19:35
[Question] Montage Jantes 4 trous - Page 2 Icon_minitimepar COXDJU Mar 24 Déc - 0:19
» carbu 1600 CC
[Question] Montage Jantes 4 trous - Page 2 Icon_minitimepar COXDJU Mar 24 Déc - 0:13
» ex lady blue....
[Question] Montage Jantes 4 trous - Page 2 Icon_minitimepar ptitdepanneur Dim 22 Déc - 16:00
[Question] Montage Jantes 4 trous - Page 2 Icon_minitimepar rsengler Mer 11 Déc - 0:42
[Question] Montage Jantes 4 trous - Page 2 Icon_minitimepar Jul 13-02 Mar 10 Déc - 21:44
[Question] Montage Jantes 4 trous - Page 2 Icon_minitimepar weber1966 Sam 7 Déc - 13:50
[Question] Montage Jantes 4 trous - Page 2 Empty
MessageSujet: Re: [Question] Montage Jantes 4 trous   [Question] Montage Jantes 4 trous - Page 2 Icon_minitimeLun 26 Jan - 14:37
Moi mes HEGGLIN sont en 14 de diametre et 5.5 de large ET34 et elle touche les rotules qd je braque a fond et ce malgré une entretoise de 13mm !
Mais ne met pas des jantes Big c'est totalement immonde lol! lol!
[Question] Montage Jantes 4 trous - Page 2 Sign1010
[Question] Montage Jantes 4 trous - Page 2 Signat10
furious
furious
Véhicules : 1302 de 71
MessageSujet: Re: [Question] Montage Jantes 4 trous   [Question] Montage Jantes 4 trous - Page 2 Icon_minitimeLun 26 Jan - 15:06
et 4 jantes tole en 5,5 ,respectivement en 185 et 195 ,ca passe au 4 coins de ma caisse et ca me remplit les ailes sans deborder ?
Promis, apres j arrete ... [Question] Montage Jantes 4 trous - Page 2 937163
MessageSujet: Re: [Question] Montage Jantes 4 trous   [Question] Montage Jantes 4 trous - Page 2 Icon_minitimeLun 26 Jan - 15:32
185 c'est nickel pour l'arriere , ca vient a fleur d'aile
Mais a lavant jen suis moins sur !
MessageSujet: Re: [Question] Montage Jantes 4 trous   [Question] Montage Jantes 4 trous - Page 2 Icon_minitimeLun 26 Jan - 18:08
185 sur du 5.5 derriere sa vient a fleur d'aile ?
tu rigoles batounet .... [Question] Montage Jantes 4 trous - Page 2 681905
le 5.5 ET25 devant sur du 185/60 passe sans toucher et vient a fleur d'aile , j'ai sa sur la 13 2
[Question] Montage Jantes 4 trous - Page 2 Dyn00310
derriere si tu veux etre "large" , te faut du 5.5 si tu veux mais avec une cale histoire d'élargir la voie et du 195 ... 185 c rikiki [Question] Montage Jantes 4 trous - Page 2 808202 , sinon plus large genre du 6.5 ou 7 [Question] Montage Jantes 4 trous - Page 2 977334
comme renal qui je crois a une calle derriere
[Question] Montage Jantes 4 trous - Page 2 Buissonub4
[Question] Montage Jantes 4 trous - Page 2 315149
MessageSujet: Re: [Question] Montage Jantes 4 trous   [Question] Montage Jantes 4 trous - Page 2 Icon_minitimeLun 26 Jan - 20:18
Pour être à fleur d'aile derrière, je vois que du 195 ou 205 sur du 5.5" (a voir pour le déport)
boumbocox
boumbocox
Véhicules : 1303 du 11/1972
MessageSujet: Re: [Question] Montage Jantes 4 trous   [Question] Montage Jantes 4 trous - Page 2 Icon_minitimeLun 26 Jan - 20:48
Bonjour tous le monde
Je viens apporte ma petite pierre.
Pour une jante de 5.5 pouce le maximun (en taille de pneu),pour rouler en securite et du 185 le 195 et le 205 etant juste tolere.Pour monter du 195 ou 205 il faut des jantes de 6p.
Pour avoir les jantes a fleur d'ailes il te faut soit une jante avec un deport plus important,soit une cale entre la roue et le moyeu.
MessageSujet: Re: [Question] Montage Jantes 4 trous   [Question] Montage Jantes 4 trous - Page 2 Icon_minitimeLun 26 Jan - 20:55
pour info j'ai des jantes d'origine en 5,5 et j'ai mis du 215 dessus et là sa rempli bien. lol!
boumbocox
boumbocox
MessageSujet: Re: [Question] Montage Jantes 4 trous   [Question] Montage Jantes 4 trous - Page 2 Icon_minitimeLun 26 Jan - 22:26
Oui c'est surement possible mais ta jante doit ressembler a une bouee sur un elephant.
Meme si ca marche il faut savoir qu'il existe un risque.
MessageSujet: Re: [Question] Montage Jantes 4 trous   [Question] Montage Jantes 4 trous - Page 2 Icon_minitimeLun 26 Jan - 22:51
petite récap:
- on parle de ET pour savoir si la jante rentre beaucoup dans l'aile ou si elle va dépasser...et si l'ET est insuffisant on règle avec une cale...sinon, ce serait trop simple
(vous voulez pas mettre du 245 de large sur des jantes en 4' non plus? [Question] Montage Jantes 4 trous - Page 2 681905 )
- les tôles repro modernes en 5.5 font ET25 (pas profond dans l'aile)
- les tôles anciennes Lemmertz en 5.5 font ET34 (profond dans l'aile); mais pour en trouver à bon compte, il faudra se lever de très bonne heure [Question] Montage Jantes 4 trous - Page 2 977334
- sur du 5.5*15, on met du 185/60 ou du 195/65 pour rouler en sécurité; on gonfle à 2bars, et c'est tout
dans tous les cas, à l'arrière il faut une cale si on veut être à fleur d'aile; c'est mon montage sur la 1302 beige, on le voit en photo!
(ET25+cale 6mm / si ET34, il faut une cale plus épaisse car ET 34 rentre plus profond...); et avec décrantage, ça modifie encore tout, car l'effet carrossage intervient [Question] Montage Jantes 4 trous - Page 2 374708
pour l'avant, il faut tester, car mon train avant est modifié
......................et sinon, la solution esthético-technique à Tintin est parfaite: ça touche nulle part, et c'est à fleur d'aile!
(ps: une solution efficace nécessite un investissement en euros conséquent...la solution miracle à pas cher...on la cherche tous! [Question] Montage Jantes 4 trous - Page 2 808202 )
MessageSujet: Re: [Question] Montage Jantes 4 trous   [Question] Montage Jantes 4 trous - Page 2 Icon_minitimeLun 26 Jan - 22:58
d'ailleurs mes jantes sont a vendre , MP si interessé lol!
Pour bien faire si vous voulez vraiment l'avoir a fleur d'aile , fodra rajouter une petite cale mais sinon le 6.5 sa va sa passe bien en ET40 [Question] Montage Jantes 4 trous - Page 2 6965
boumbocox
boumbocox
MessageSujet: Re: [Question] Montage Jantes 4 trous   [Question] Montage Jantes 4 trous - Page 2 Icon_minitimeLun 26 Jan - 23:23
voila tout est clair
furious
furious
MessageSujet: Re: [Question] Montage Jantes 4 trous   [Question] Montage Jantes 4 trous - Page 2 Icon_minitimeDim 1 Fév - 14:50
merci pour ces precisions, la c est clair ... [Question] Montage Jantes 4 trous - Page 2 808202
furious
furious
MessageSujet: Re: [Question] Montage Jantes 4 trous   [Question] Montage Jantes 4 trous - Page 2 Icon_minitimeLun 23 Fév - 15:28
j ai enfin trouvé des jantes pour coller sur mon 1302
des big ET 26 en 5,5
Sachant que je suis rabaissé -5 cm (ressorts courts) ,certains d entre vous m ont preconisé de monter du 175 devant (car le 185 risque de frotter )
Derriere ,la monte va dependre de devant (si 175 devant ,ca sera 185 derriere ou 185 devant et 195 derriere ): tout cela afin d obtenir un montage homogene
Vos avis ?
PS: ca me ferait assez [Question] Montage Jantes 4 trous - Page 2 110880 de me gourer dans la monte des pneus ....
huggy27
MessageSujet: Re: [Question] Montage Jantes 4 trous   [Question] Montage Jantes 4 trous - Page 2 Icon_minitimeLun 23 Fév - 16:02
voit aussi la difference de prix car je croit que le 175 n es pas donné
apres tu peut mettre du 185/65 au 4 coin de la voiture pour etre en regle...
furious
furious
MessageSujet: Re: [Question] Montage Jantes 4 trous   [Question] Montage Jantes 4 trous - Page 2 Icon_minitimeLun 23 Fév - 18:56
ok mais est ce que le 185x65 passe devant sur une jante ET 26 ??
MessageSujet: Re: [Question] Montage Jantes 4 trous   [Question] Montage Jantes 4 trous - Page 2 Icon_minitimeLun 23 Fév - 19:07
le 185 passe devant ... - 5 ; on est pas tres bas ...
Moi je suis en 185/60 sur des ET25 , ça fait sympa [Question] Montage Jantes 4 trous - Page 2 315149
MessageSujet: Re: [Question] Montage Jantes 4 trous   [Question] Montage Jantes 4 trous - Page 2 Icon_minitimeLun 23 Fév - 23:59
je veux pas être rabat-joie, mais... même si c'est du 185/65 aux 4 coins, c'est pas en règle: la monte d'origine est 165/80/15; n'importe quelle autre monte est "non conforme" [Question] Montage Jantes 4 trous - Page 2 977334
bon, je suis d'accord: mettre du 185/65/15 aux 4 coins est simple à gérer [Question] Montage Jantes 4 trous - Page 2 374708
ah oui, encore un truc (je l'ai déjà dit [Question] Montage Jantes 4 trous - Page 2 808202 ): le montage à Tintin est homogène; et sur des Big 5.5, on peut aussi mettre du 185/60 devant et du 195/65 derrière
huggy27
MessageSujet: Re: [Question] Montage Jantes 4 trous   [Question] Montage Jantes 4 trous - Page 2 Icon_minitimeMar 24 Fév - 0:39
d origine la monte est 155/80r15 non ?
donc la correspondance pour avoir la meme circonference et etre monté plus large c est :
175/70r15
185/60r16 et
185/65r15
on peut aussi:
195/65r15
205/60r15
345/35r15
et pour le fun
255/30r19
ensuite si en premiere monte si on avait du 165/80r15 on pourrait mettre
175/70r16
175/75r15
195/60r16
205/60r17
et meme du 275/75r20
MessageSujet: Re: [Question] Montage Jantes 4 trous   [Question] Montage Jantes 4 trous - Page 2 Icon_minitimeMar 24 Fév - 1:07
c'est parfaitement exact; après, ça dépend du contrôleur technique, s'il te suit dans ton raisonnement (ou pas), mais c'est un débat dans lequel je ne veux pas intervenir!
au moins, Furious pourra pas dire qu'on a pas donné TOUTES les infos, hein! [Question] Montage Jantes 4 trous - Page 2 681905
en fait, je crois que ce qui intéressait Furious dans sa question d'origine c'était le côté "look homogène" avant tout
huggy27
MessageSujet: Re: [Question] Montage Jantes 4 trous   [Question] Montage Jantes 4 trous - Page 2 Icon_minitimeMar 24 Fév - 1:28
oui tu as raison
moi c est justement mon controleur technique qui ma montrer ces correspondances
(que tout les centre son censsé avoir)
pour ne pas etre embeter par la policia
MessageSujet: Re: [Question] Montage Jantes 4 trous   [Question] Montage Jantes 4 trous - Page 2 Icon_minitimeMar 24 Fév - 2:19
Personnellement , je monterais du 185/60 et 195/65 .... apres c'est toi qui voit [Question] Montage Jantes 4 trous - Page 2 977334
furious
furious
MessageSujet: Re: [Question] Montage Jantes 4 trous   [Question] Montage Jantes 4 trous - Page 2 Icon_minitimeMar 24 Fév - 15:12
des que je reçois mes jantes, je commande mes pneus
merci à tous de vos precieux conseils
MessageSujet: Re: [Question] Montage Jantes 4 trous   [Question] Montage Jantes 4 trous - Page 2 Icon_minitimeMar 24 Fév - 15:24
c'est fait pour sa un forum [Question] Montage Jantes 4 trous - Page 2 39722 [Question] Montage Jantes 4 trous - Page 2 315149
piersonne
Véhicules : golf 2 gti 16s 87 1302 1971
MessageSujet: Re: [Question] Montage Jantes 4 trous   [Question] Montage Jantes 4 trous - Page 2 Icon_minitimeVen 4 Sep - 20:40
salut les gars, je deterre ce topic, j'en avais cree un aussi je crois mais je le trouve plus, arf le nul
bon j'ai mes jantes 914 2l, en 5.5 de large me semble t'il, ET? je ne l'ai jamais su
montage en 185-65-15
derriere impec ca passe , cest super joli, ptet un jour foutre des 6mm en cales, histoire de les ressortir, devant cest le hic total:
alors deja au depart javais un plomb a linterieur clipsé sur la jante et des plomb collés, le plomb clipé touchait la jante... pfff
reequilibrage etc que des plombs collés, mais la le pneu touche les ressorts.. pfff enfin ca frotouille, donc mon shop ma parlé aue 6mm meme si cest peu suffira a ce que ca ne touche plus.. votre avis? c''est bon? et est ce que 8-9mm de filetage restant disponible sur mon goujon est siffisant ou dois je en racheter dautres plus long [Question] Montage Jantes 4 trous - Page 2 110880 j'aimerais eviter, ils sont neuf..
et pour la vis de rotule qui depasse en dessous, tous les shop specialiste vw les coupent a ras la vis, mais a la scie a main car c'est un ecrou nilstop, donc pas faire chauffer la partie plastique
franck dm
franck dm
MessageSujet: Re: [Question] Montage Jantes 4 trous   [Question] Montage Jantes 4 trous - Page 2 Icon_minitimeSam 5 Sep - 11:10
tu as aussi les Empi8 qui ne sont pas chères, tu les trouve en plusieurs couleurs, tu sais y mettre tes pneus d'origine.
Si tu y mets des jantes modernes tu fera un recul de 20ans dans la mode VW aircooled (tunning des années 80). [Question] Montage Jantes 4 trous - Page 2 400181 Regarde les 50 premiers n° de VWmag, tu comprendras de quoi je parle [Question] Montage Jantes 4 trous - Page 2 15984
Maintenant chacun ses gouts [Question] Montage Jantes 4 trous - Page 2 148655 même avec des vilaines godasses ça reste une VW aircooled.
http://franckdm.skyrock.com/
