» Les photos des bannières
Yellow 1302 by evangelion64 - Page 6 Icon_minitimepar burgon Aujourd'hui à 1:07
Yellow 1302 by evangelion64 - Page 6 Icon_minitimepar Billocox Hier à 22:41
Yellow 1302 by evangelion64 - Page 6 Icon_minitimepar SuperBat Hier à 19:42
Yellow 1302 by evangelion64 - Page 6 Icon_minitimepar Mutos Hier à 19:25
Yellow 1302 by evangelion64 - Page 6 Icon_minitimepar cjcox Hier à 11:10
Yellow 1302 by evangelion64 - Page 6 Icon_minitimepar COX1303 Mer 17 Juil - 10:36
Yellow 1302 by evangelion64 - Page 6 Icon_minitimepar Cox-34 Mer 17 Juil - 2:48
Yellow 1302 by evangelion64 - Page 6 Icon_minitimepar Billocox Mar 16 Juil - 22:04
Yellow 1302 by evangelion64 - Page 6 Icon_minitimepar Billocox Mar 16 Juil - 22:00
Yellow 1302 by evangelion64 - Page 6 Icon_minitimepar Billocox Mar 16 Juil - 21:54
Yellow 1302 by evangelion64 - Page 6 Icon_minitimepar Billocox Mar 16 Juil - 21:48
Yellow 1302 by evangelion64 - Page 6 Icon_minitimepar Eoleys Lun 15 Juil - 11:46
Yellow 1302 by evangelion64 - Page 6 Icon_minitimepar Billocox Mar 9 Juil - 12:42
Yellow 1302 by evangelion64 - Page 6 Icon_minitimepar weber1966 Mar 9 Juil - 10:57
Yellow 1302 by evangelion64 - Page 6 Icon_minitimepar criss0067 Jeu 4 Juil - 11:48
Yellow 1302 by evangelion64 - Page 6 Icon_minitimepar Cox-34 Jeu 4 Juil - 2:51
Yellow 1302 by evangelion64 - Page 6 Icon_minitimepar Cox-34 Mer 3 Juil - 22:08
Yellow 1302 by evangelion64 - Page 6 Icon_minitimepar ben ze frog Mar 2 Juil - 11:48
Yellow 1302 by evangelion64 - Page 6 Icon_minitimepar fabrice.cox Lun 1 Juil - 17:12
Yellow 1302 by evangelion64 - Page 6 Icon_minitimepar JP78 Dim 30 Juin - 13:34
Aller à la page : Précédent  1 ... 5, 6, 7 ... 15 ... 24  Suivant
Yellow 1302 by evangelion64 - Page 6 Empty
MessageSujet: Re: Yellow 1302 by evangelion64   Yellow 1302 by evangelion64 - Page 6 Icon_minitimeVen 23 Sep - 20:22
Oui.
Va dans un garage et emprunte une clé adaptée.
MessageSujet: Re: Yellow 1302 by evangelion64   Yellow 1302 by evangelion64 - Page 6 Icon_minitimeSam 24 Sep - 0:03
tiens look voici le même problème que toi enfin si cela est bien le même Yellow 1302 by evangelion64 - Page 6 559141 mes ailes arrirères ne sont pas les même donc look la différence....
Yellow 1302 by evangelion64 - Page 6 Roue_a10
MessageSujet: Re: Yellow 1302 by evangelion64   Yellow 1302 by evangelion64 - Page 6 Icon_minitimeSam 24 Sep - 10:14
oui je pense que c'est la même chose
MessageSujet: Re: Yellow 1302 by evangelion64   Yellow 1302 by evangelion64 - Page 6 Icon_minitimeMer 28 Sep - 14:12
la sortie de ce we à remonter encore des soucis ... mes pneus frottent sur les ailles ...
les jantes en ET20 ne sont pas terribles car cela empeche le pneu de rentrer dans l'aile
cependant les empi 8 en ET30 sont assez rare... il va falloir que je durcisse les combinés AV, snif ...
Sinon question tenue de route, ma cox est beaucoup plus stable à 110 Km/h, il faudrait faire le paralleliseme maintenant pour etre au top.
quelqu'un à une adresse dans le 78 ?
MessageSujet: Re: Yellow 1302 by evangelion64   Yellow 1302 by evangelion64 - Page 6 Icon_minitimeJeu 29 Sep - 7:54
A tu essayé chez les spécialistes genre feu vert, midas, AD ect...
Moi je règle mon parallèlisme à la corde (et c'est passé nickel au CT).
Bloque une corde sous la roue arrière et vient tangenter la corde sur le milieu de la roue avant, elle doit toucher les deux cotés du pneu (cela ne fonctionne pas si tes voies arriere sont plus large que l'avant).
MessageSujet: Re: Yellow 1302 by evangelion64   Yellow 1302 by evangelion64 - Page 6 Icon_minitimeJeu 29 Sep - 8:45
ben a chaque fois il faut tout leur expliquer, j'aurais préférer passer chez un pro qui sache faire ... avec le club de Rambouillet vous n'avez une adresse ?
sinon je voudrais faire un réglage au laser plutôt avec le carrossage AV/AR
MessageSujet: Re: Yellow 1302 by evangelion64   Yellow 1302 by evangelion64 - Page 6 Icon_minitimeJeu 29 Sep - 20:57
mef pour le carrossage car ils ne le font pas tous et n'oubli pas d'apporter les règlages pour nos train avant sinon ils risqueraient de te faire un réglage autre que macpherson
MessageSujet: Re: Yellow 1302 by evangelion64   Yellow 1302 by evangelion64 - Page 6 Icon_minitimeSam 8 Oct - 22:44
Pour oublier mes petits problème de pneus et serrage je me suis fait un petit plaisir:
une paire de rétro obus (de mini austin) :
Yellow 1302 by evangelion64 - Page 6 P1060521
par contre le montage ne sera pas évident pour serrer la vis à travers la porte ...
avez vous une méthode à préconiser ?
Bon We à tous
MessageSujet: Re: Yellow 1302 by evangelion64   Yellow 1302 by evangelion64 - Page 6 Icon_minitimeSam 8 Oct - 22:55
Pourquoi ne pas les mettres en lieu et place des origines
Si le diamètre du filtage est plus petit tu prend une tige fileté de la taille désiré tu perce dedans et tu taraude au diamètre de ceux de mini .
MessageSujet: Re: Yellow 1302 by evangelion64   Yellow 1302 by evangelion64 - Page 6 Icon_minitimeSam 8 Oct - 23:01
Je vais prendre le trou d'origine mais il faut que j'arrive à serrer le boulon à travers la porte, c'est difficile d’accès avec la main...
Sinon la vis mini est trop courte pour utiliser le socle en biseau VW, je vais le serrer directement sur la carrosserie, la rondelle vendu est assez large
Blue174
Blue174
Ca ira peut-être pas pour le réglage des rétros et y voir quelquechose dedans Yellow 1302 by evangelion64 - Page 6 15984
MessageSujet: Re: Yellow 1302 by evangelion64   Yellow 1302 by evangelion64 - Page 6 Icon_minitimeSam 8 Oct - 23:09
oui j'ai déjà lu souvent sur le net mais sur ces obus on peut pivoter le pied
mais c'est plus pour le look, je te l'accorde
d'ailleurs tu en as toi ? tu y vois ?
Blue174
Blue174
MessageSujet: Re: Yellow 1302 by evangelion64   Yellow 1302 by evangelion64 - Page 6 Icon_minitimeSam 8 Oct - 23:17
J'ai des rétros obus mais je n'y vois rien lol! un bon pivotement du corps ya que ça de vrai.
MessageSujet: Re: Yellow 1302 by evangelion64   Yellow 1302 by evangelion64 - Page 6 Icon_minitimeSam 8 Oct - 23:20
j'ai deja le pb sur la moto, cela ne changera pas sur la cox
Blue174
Blue174
MessageSujet: Re: Yellow 1302 by evangelion64   Yellow 1302 by evangelion64 - Page 6 Icon_minitimeSam 8 Oct - 23:28
Vive les pièces d'origine lol!
MessageSujet: Re: Yellow 1302 by evangelion64   Yellow 1302 by evangelion64 - Page 6 Icon_minitimeDim 9 Oct - 18:35
+1 j'en ai sur ma cox, et je confirme on y vois rien Yellow 1302 by evangelion64 - Page 6 110880
MessageSujet: Re: Yellow 1302 by evangelion64   Yellow 1302 by evangelion64 - Page 6 Icon_minitimeMar 18 Oct - 22:24
Hello
je reviens avec mon bruit !
malgré un serrage avec une barre de 2 mètres des axes de roue AR
j'ai toujours un bruit de "tac tac tac" quand je roule ( sans freiner) à 10 Km/h
par contre j'ai l'impression que cela provient de l'avant
j'ai donc resserré un peut les roulements AV mais rien..
d’où cela pourrait venir selon vous ?
roue voilée ?
roulement HS ? (tout est neuf)
pièce qui frotte ?
MessageSujet: Re: Yellow 1302 by evangelion64   Yellow 1302 by evangelion64 - Page 6 Icon_minitimeMar 18 Oct - 22:35
t'as contrôlé les vis des cardans?
et tes roues av et arr n'ont pas de jeux (voiture levée bien sûr)
MessageSujet: Re: Yellow 1302 by evangelion64   Yellow 1302 by evangelion64 - Page 6 Icon_minitimeMar 18 Oct - 22:47
j'ai deja resserré les cardans coté roue
et je ne ressens pas de jeu dans les 4 roues levées...
MessageSujet: Re: Yellow 1302 by evangelion64   Yellow 1302 by evangelion64 - Page 6 Icon_minitimeSam 29 Oct - 16:59
Bon je ne donne pas trop de news, je suis en arrêt pour blocage du dos...
sinon j'ai toujours mon bruit de clac clac et j'ai bien vérifié cela provient de l'avant
Quand je freine au frein à main > le bruit reste
Quand je freine à la pédale, le bruit disparait
j'ai resserré un peu les roulements avant mais toujours rien ...
vos idées ?
MessageSujet: Re: Yellow 1302 by evangelion64   Yellow 1302 by evangelion64 - Page 6 Icon_minitimeSam 29 Oct - 18:02
Hello!
Tu as regardé si tes garnitures de frein n'étaient pas décollées?? Car c'est clair que si ton problème vient des freins avants, le fait de freiner au frein à main ne va rien changer car il agit seulement sur l'essieu arrière.
Florian
MessageSujet: Re: Yellow 1302 by evangelion64   Yellow 1302 by evangelion64 - Page 6 Icon_minitimeSam 29 Oct - 18:25
pour info, j'ai 4 freins à disques,
mais je ne peux rien régler au niveau des plaquettes?
j'ai utilisé le frein à main pour prouver que ce n’était le train AR
MessageSujet: Re: Yellow 1302 by evangelion64   Yellow 1302 by evangelion64 - Page 6 Icon_minitimeSam 29 Oct - 19:34
Oups désolé, j'avais plus repensé que tu étais en disques... plus haut tu dis à 10km/h mais c'est seulement à cette vitesse?
Florian
MessageSujet: Re: Yellow 1302 by evangelion64   Yellow 1302 by evangelion64 - Page 6 Icon_minitimeDim 30 Oct - 10:37
je pense que le bruit continu après 10 Km/h mais après le bruit du moteur prend le dessus donc je n'entend pas bien
j'ai l'impression que c'est plus fort quand je tourne (ex un rond points )
MessageSujet: Re: Yellow 1302 by evangelion64   Yellow 1302 by evangelion64 - Page 6 Icon_minitimeDim 30 Oct - 18:32
tu as bien fait un chanfrein au niveau des plaquettes pour que rien ne touche une fois monté auprès des disques...
Page 6 sur 24Aller à la page : Précédent  1 ... 5, 6, 7 ... 15 ... 24  Suivant
