GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE  Icon_minitimepar gibolin78 Hier à 21:19
GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE  Icon_minitimepar rsengler Hier à 14:18
GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE  Icon_minitimepar le fous des cox Dim 1 Déc - 15:01
GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE  Icon_minitimepar weber1966 Sam 23 Nov - 16:41
GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE  Icon_minitimepar cjcox Mer 20 Nov - 12:04
GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE  Icon_minitimepar Jul 13-02 Mar 19 Nov - 23:43
GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE  Icon_minitimepar Cox-34 Mar 19 Nov - 17:30
GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE  Icon_minitimepar weber1966 Lun 18 Nov - 21:16
GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE  Icon_minitimepar Cox-34 Jeu 14 Nov - 18:49
GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE  Icon_minitimepar Cox-34 Jeu 14 Nov - 18:35
GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE  Icon_minitimepar SuperBat Mer 13 Nov - 20:43
GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE  Icon_minitimepar GUILLAUME Mer 13 Nov - 7:24
GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE  Icon_minitimepar Ju7 Mar 5 Nov - 0:51
GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE  Icon_minitimepar marcc Jeu 31 Oct - 15:45
GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE  Icon_minitimepar bertrand53 Mer 30 Oct - 11:40
GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE  Icon_minitimepar SV Lun 28 Oct - 18:16
GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE  Icon_minitimepar weber1966 Ven 18 Oct - 19:13
GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE  Icon_minitimepar weber1966 Mar 15 Oct - 19:13
GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE  Icon_minitimepar Peck Lun 14 Oct - 20:31
GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE  Icon_minitimepar cox911 Dim 13 Oct - 20:49
titicox59
titicox59
Véhicules : cox 1303 - 1973
GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE  Empty
MessageSujet: GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE    GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE  Icon_minitimeMar 30 Avr - 17:26
Vous allez peut-être pouvoir m'aider car j'ai un bruit de grincement /couinement quand je démarre (ou que la voiture cale) ,c'est à dire lors de la phase de lancement (ou arret) moteur quand celui-ci vibre et donc fait vibrer la caisse... GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE  110880
Par contre quand il démarre au quart de tour le phénomène ne se produit plus...
C'est vraiment quand la voiture vibre en essayant de lancer la moteur ou que celui-ci cale.
C'est difficile à localiser car ca ne dure que 2 ou 3secondes et encore...
Il me semble que c'est surtout après un arrret prolongé de la voiture donc un démarrage un peu hasardeuux à froid.
Bref je sais pas si je me suis bien fait comprendre, mais si quelqu'un à déja eu ce phénomène ca m'aiderait.
merci GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE  808202
MessageSujet: Re: GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE    GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE  Icon_minitimeMar 30 Avr - 17:48
Silentbloc de boite HS ?
titicox59
titicox59
MessageSujet: Re: GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE    GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE  Icon_minitimeMar 30 Avr - 18:07
Hello
Je viens justement de lire quelques postes à ce sujet et apparemment des silents blocs de boite HS procurent bien de grosses vibrations sote de balourd dans toute la voiture.
J'ai lu aussi que cela pourrait provenir aussi de l'embrayage car c'est vrai que j'ai des vibrations dans la pédale en embrayant surtout en première et MA.
Il ne patine pas mais un peu comme une sensation d'abs qui se déclenche et les petites vibrations ressenties dans la pédale de frein.
Ceci dit au point de faire trembler la caisse à ce point cela m'étonnerais...
J'avais prévu de repoussé le démontage moteur afin de profiter de la cox , mais je crains devoir le faire plus tôt que prévu. GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE  110880
MessageSujet: Re: GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE    GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE  Icon_minitimeMar 30 Avr - 19:02
l'embrayage se règle avec une vis papillon à pan carré côté fourchette de boîte!
si c'est mal réglé, cela entraîne aussi des vibrations en décollant la voiture sur les premiers mètres
titicox59
titicox59
MessageSujet: Re: GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE    GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE  Icon_minitimeMar 30 Avr - 19:14
Ok merci ca ne coute rien d'essayer...
Cela n'à rien à voir mais est-ce normal que ma pédale d'embrayage "ressorte" plus que celle de frein et accélérateur (voir photo)
GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE  20130110
MessageSujet: Re: GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE    GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE  Icon_minitimeMar 30 Avr - 19:27
oui, normal! GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE  998756
MessageSujet: Re: GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE    GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE  Icon_minitimeMar 30 Avr - 20:04
tu n'aurais pas deux soucis distinct ? ton couinement au démarrage à froid fait plutôt penser à un soucis de démarreur : piece usée, qui tourne moins bien à froid ? bobinage du démarreur ?
MessageSujet: Re: GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE    GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE  Icon_minitimeMar 30 Avr - 22:43
Si cela grince, c'est le disque d'embrayage qui frotte.
Si tes silends blocs sont mort ta voiture tremble comme une folle.
titicox59
titicox59
MessageSujet: Re: GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE    GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE  Icon_minitimeJeu 2 Mai - 10:47
Oui mais si c'était le disque d'embrayage qui frotte ca le ferait à chaque démarrage?
Dans mon cas c'est un démarrage à froid.
Je pense aussi au démarreur qui grippe à froid...ca me parait jouable.
Quant aux tremblements certainement les silents blocs HS.
Donc 2 problèmes... GRINCEMENT / COUINEMENT/ VIBRATION AU DEMARRAGE  110880
