culasses 133 DA introuvable!?! solution --1600?? Icon_minitimepar haguarde Hier à 7:19
culasses 133 DA introuvable!?! solution --1600?? Icon_minitimepar snake862006 Ven 15 Nov - 1:34
culasses 133 DA introuvable!?! solution --1600?? Icon_minitimepar Cox-34 Jeu 14 Nov - 18:57
culasses 133 DA introuvable!?! solution --1600?? Icon_minitimepar Cox-34 Jeu 14 Nov - 18:49
culasses 133 DA introuvable!?! solution --1600?? Icon_minitimepar Cox-34 Jeu 14 Nov - 18:35
culasses 133 DA introuvable!?! solution --1600?? Icon_minitimepar SuperBat Mer 13 Nov - 20:43
culasses 133 DA introuvable!?! solution --1600?? Icon_minitimepar GUILLAUME Mer 13 Nov - 7:24
culasses 133 DA introuvable!?! solution --1600?? Icon_minitimepar Ju7 Mar 5 Nov - 0:51
culasses 133 DA introuvable!?! solution --1600?? Icon_minitimepar marcc Jeu 31 Oct - 15:45
culasses 133 DA introuvable!?! solution --1600?? Icon_minitimepar gibolin78 Mer 30 Oct - 20:23
culasses 133 DA introuvable!?! solution --1600?? Icon_minitimepar bertrand53 Mer 30 Oct - 11:40
culasses 133 DA introuvable!?! solution --1600?? Icon_minitimepar SV Lun 28 Oct - 18:16
culasses 133 DA introuvable!?! solution --1600?? Icon_minitimepar weber1966 Ven 18 Oct - 19:13
culasses 133 DA introuvable!?! solution --1600?? Icon_minitimepar weber1966 Mar 15 Oct - 19:13
culasses 133 DA introuvable!?! solution --1600?? Icon_minitimepar Peck Lun 14 Oct - 20:31
culasses 133 DA introuvable!?! solution --1600?? Icon_minitimepar cox911 Dim 13 Oct - 20:49
culasses 133 DA introuvable!?! solution --1600?? Icon_minitimepar SuperBat Sam 12 Oct - 18:46
culasses 133 DA introuvable!?! solution --1600?? Icon_minitimepar weber1966 Mar 8 Oct - 11:03
culasses 133 DA introuvable!?! solution --1600?? Icon_minitimepar jipi37 Sam 5 Oct - 18:29
culasses 133 DA introuvable!?! solution --1600?? Icon_minitimepar fufu Sam 5 Oct - 16:12
2m10
2m10
Masculin Nombre de messages : 71
Véhicules : cox 1302 70 en cours de restauration
e46 330xd pour ts les jours!
ford consul capri 62 en attente de restauration!
culasses 133 DA introuvable!?! solution --1600?? Empty
MessageSujet: culasses 133 DA introuvable!?! solution --1600??   culasses 133 DA introuvable!?! solution --1600?? Icon_minitimeSam 3 Aoû - 11:58
bonjour a tous,
voila je vais bientôt remonter mon moteur (1300 double admission moteur AB) qui avait été déculassé pour contrôle résultat les deux culasses fendues..
du classique quoi me direz vous, sauf que je n arrive pas en retrouvé une paire...
cela fait 2 mois que je cherche sur les forums sur Lbc etcc rien! neuf sur slide ca fait 450 ou 500 e euros ce qui est énorme je trouve
j ai vu sur mecatechnic qu il existe un kit 1600 mahle a 520 e je crois tout complet, qu es ce que ca vaut vraiment?
j en suis a me dire, quitte a mettre 500e mieux vaut peut être tout passer en neuf et en cylindrée plus élevé pour un peu plus de puissance et un meilleur couple?!
je précise pour finir que c est un deuxième véhicule, qui va rouler le dimanche, de temps en temps quand il fera beau donc a la base j avais prévu de garder le moteur d origine, je ne souhaite pas en faire une bête de course mais je cherche a trouver un bon compromis pour avoir qq chose de fiable voila! merci a tous de me dire ceux que vous en dites!
MessageSujet: Re: culasses 133 DA introuvable!?! solution --1600??   culasses 133 DA introuvable!?! solution --1600?? Icon_minitimeSam 3 Aoû - 17:58
500 euros pour deux culasses complètes et neuves ce n'est pas exagéré hein, on a une chance incroyable de trouver de la pièce neuve pour nos voitures au prix où on trouve des occasions pourries sur des voitures plus récentes...
Mais sinon oui à prix équivalent c'est plus intéressant de passer en 1600.
2m10
2m10
MessageSujet: Re: culasses 133 DA introuvable!?! solution --1600??   culasses 133 DA introuvable!?! solution --1600?? Icon_minitimeSam 3 Aoû - 20:45
ok.. et ca impose quelle modif mise a part le fameux kit complet? il faut modifier l allumage? ou autre
et as tu une idee de ce qu il vaut ce kit?
MessageSujet: Re: culasses 133 DA introuvable!?! solution --1600??   culasses 133 DA introuvable!?! solution --1600?? Icon_minitimeSam 3 Aoû - 20:54
Ça peut rouler tel quel avec le 31 pict que tu dois avoir sur ton 1300 et sa pipe, sinon un 34 pict et sa pipe c'est pas plus mal. Je ne sais pas ce que vaut le kit dont tu parles mais en général Mahle c'est de la bonne came, par contre je suis assez surpris par le prix que tu annonces.
2m10
2m10
MessageSujet: Re: culasses 133 DA introuvable!?! solution --1600??   culasses 133 DA introuvable!?! solution --1600?? Icon_minitimeSam 3 Aoû - 23:22
oui je crois que c est un 31 pict 3 ou 4, et niveau filtre a air tu me conseilles quoi?
voici le lien du kit; ca a pas l air mal..
http://www.mecatechnic.com/pieces.asp?code0_ref=COX&code1_ref=MT1&code2_ref=KIT&code3_ref=COM&langue=FR
2m10
2m10
MessageSujet: Re: culasses 133 DA introuvable!?! solution --1600??   culasses 133 DA introuvable!?! solution --1600?? Icon_minitimeSam 3 Aoû - 23:25
MessageSujet: Re: culasses 133 DA introuvable!?! solution --1600??   culasses 133 DA introuvable!?! solution --1600?? Icon_minitimeSam 3 Aoû - 23:28
Le prix me surprend vraiment ! Un kit cylindrée mahle en 1600 c'est 190 euros seul, ça laisse pas beaucoup pour les culasses...
MessageSujet: Re: culasses 133 DA introuvable!?! solution --1600??   culasses 133 DA introuvable!?! solution --1600?? Icon_minitimeSam 3 Aoû - 23:30
Filtre à air d'origine.
Il serait bon de connaitre les références ou au moins les caractéristiques des culasses, culasse sans plomb culot court ça ne veut rien dire...
MessageSujet: Re: culasses 133 DA introuvable!?! solution --1600??   culasses 133 DA introuvable!?! solution --1600?? Icon_minitimeSam 3 Aoû - 23:47
Ça fait 150 euros la culasse complète si on déduit le prix du reste, franchement je ne vois pas DU TOUT comment c'est possible avec une qualité correcte. Ou alors c'est des culasses bas de gamme mais nues et là ça colle à peu près niveau prix.
2m10
2m10
MessageSujet: Re: culasses 133 DA introuvable!?! solution --1600??   culasses 133 DA introuvable!?! solution --1600?? Icon_minitimeLun 5 Aoû - 1:57
ok, donc vous pensez que je devrais appeler meca? pour avoir les refs des culasses ?!
a moins que quelqu un ai une autre solution pour ces maudites culasses 1300...
MessageSujet: Re: culasses 133 DA introuvable!?! solution --1600??   culasses 133 DA introuvable!?! solution --1600?? Icon_minitimeLun 5 Aoû - 11:09
Oui
MessageSujet: Re: culasses 133 DA introuvable!?! solution --1600??   culasses 133 DA introuvable!?! solution --1600?? Icon_minitimeLun 5 Aoû - 12:16
Surtout demande leur bien si elles sont complètes ou nues, ça t'évitera une mauvaise surprise.
2m10
2m10
MessageSujet: Re: culasses 133 DA introuvable!?! solution --1600??   culasses 133 DA introuvable!?! solution --1600?? Icon_minitimeMer 7 Aoû - 23:36
ok les gars, je vous tiens au courant.
2m10
2m10
MessageSujet: Re: culasses 133 DA introuvable!?! solution --1600??   culasses 133 DA introuvable!?! solution --1600?? Icon_minitimeMar 20 Aoû - 0:06
bon alors un petit retour, j ai contacté mecatechnic, pour le kit qui est finalement un AAproduct et non un mahle pour le prix cité précédemment, les culasses sont avec les soupapes il faut recuperer les culbuteurs sur mes anciennes culasses 1300 voila le kit est livré complet avec les bougies et la pochettes de joints.
2m10
2m10
MessageSujet: Re: culasses 133 DA introuvable!?! solution --1600??   culasses 133 DA introuvable!?! solution --1600?? Icon_minitimeMar 20 Aoû - 0:12
sinon j ai un ami qui as reçu a me dégotté une culasse en 1300 DA estampillée MEXICO, même diamètre pour les soupapes (35 et 30) sauf que lorsque je la pose sur les cylindres elle ne rentre pas!! ma question est, le diamètre d emboitement de la culasse dans le cylindre varie elle d une vw a une mexico?
deuxième chose il en avait une autre qui trainait mais la les soupapes font 35 et 32 a peu pres, je ne peud rien en faire non plus???
tout en sachant que je suis au courant que l on ne peut monter deux culasses différentes..
MessageSujet: Re: culasses 133 DA introuvable!?! solution --1600??   culasses 133 DA introuvable!?! solution --1600?? Icon_minitimeMar 20 Aoû - 13:32
Je persiste à dire que des culasses neuves et complètes pour 300 euros la paire il y a un truc qui cloche... À croire que certains pros n'ont toujours pas compris la leçon des cylindres de frein à 9.90 EUR.
2m10
2m10
MessageSujet: Re: culasses 133 DA introuvable!?! solution --1600??   culasses 133 DA introuvable!?! solution --1600?? Icon_minitimeMar 20 Aoû - 22:42
ecoute j en sais rien moi, en tout cas j ai regardé des retours de clients je n ai pas vu grand chose de negatif donc bon..
