Branchement pompe a essence ! - Page 2 Icon_minitimepar snake862006 Ven 15 Nov - 1:34
Branchement pompe a essence ! - Page 2 Icon_minitimepar Cox-34 Jeu 14 Nov - 18:57
Branchement pompe a essence ! - Page 2 Icon_minitimepar Cox-34 Jeu 14 Nov - 18:55
Branchement pompe a essence ! - Page 2 Icon_minitimepar Cox-34 Jeu 14 Nov - 18:49
Branchement pompe a essence ! - Page 2 Icon_minitimepar Cox-34 Jeu 14 Nov - 18:35
Branchement pompe a essence ! - Page 2 Icon_minitimepar SuperBat Mer 13 Nov - 20:43
Branchement pompe a essence ! - Page 2 Icon_minitimepar GUILLAUME Mer 13 Nov - 7:24
Branchement pompe a essence ! - Page 2 Icon_minitimepar Ju7 Mar 5 Nov - 0:51
Branchement pompe a essence ! - Page 2 Icon_minitimepar marcc Jeu 31 Oct - 15:45
Branchement pompe a essence ! - Page 2 Icon_minitimepar gibolin78 Mer 30 Oct - 20:23
Branchement pompe a essence ! - Page 2 Icon_minitimepar bertrand53 Mer 30 Oct - 11:40
Branchement pompe a essence ! - Page 2 Icon_minitimepar SV Lun 28 Oct - 18:16
Branchement pompe a essence ! - Page 2 Icon_minitimepar weber1966 Ven 18 Oct - 19:13
Branchement pompe a essence ! - Page 2 Icon_minitimepar weber1966 Mar 15 Oct - 19:13
Branchement pompe a essence ! - Page 2 Icon_minitimepar Peck Lun 14 Oct - 20:31
Branchement pompe a essence ! - Page 2 Icon_minitimepar cox911 Dim 13 Oct - 20:49
Branchement pompe a essence ! - Page 2 Icon_minitimepar SuperBat Sam 12 Oct - 18:46
Branchement pompe a essence ! - Page 2 Icon_minitimepar weber1966 Mar 8 Oct - 11:03
Branchement pompe a essence ! - Page 2 Icon_minitimepar jipi37 Sam 5 Oct - 18:29
Branchement pompe a essence ! - Page 2 Icon_minitimepar fufu Sam 5 Oct - 16:12
Branchement pompe a essence ! - Page 2 Empty
MessageSujet: Re: Branchement pompe a essence !   Branchement pompe a essence ! - Page 2 Icon_minitimeSam 21 Déc - 17:49
Si sa peut être utile
voilà une tof vue sur le net
Branchement pompe a essence ! - Page 2 14867810
MessageSujet: Re: Branchement pompe a essence !   Branchement pompe a essence ! - Page 2 Icon_minitimeSam 21 Déc - 18:09
Ah ouais super utile au moins la c'est super clair !
Branchement pompe a essence ! - Page 2 Sign1010
Branchement pompe a essence ! - Page 2 Signat10
MessageSujet: Re: Branchement pompe a essence !   Branchement pompe a essence ! - Page 2 Icon_minitimeSam 21 Déc - 18:16
Avant de te prendre la tête avec ton réservoir, tu devrais tester l'arrivée à la pompe et dans le carbu lui même!
Branchement pompe a essence ! - Page 2 Cox19610
Puis si elle ne démarre pas comme ça, débranche la durite qui monte au carbu! Si en la retirant l'essence est en pression, et que tu as comme un effet d'ouverture de bouteille de soda, tu as des chances que ton pointeau de descende plus!
Branchement pompe a essence ! - Page 2 Solex110
Quand ce dernier ne descend plus, il bloque l'essence de la pompe pour ne pas continuer le remplissage alors que la cuve est pleine et éviter la noyade!
Bonne chance! J'ai eu ça, sur la mienne y'a pas longtemps!
MessageSujet: Re: Branchement pompe a essence !   Branchement pompe a essence ! - Page 2 Icon_minitimeSam 21 Déc - 18:19
Bah pour tester la pompe j'ai défait la durite qui arrive au carbu et en mettant contact rien ne sort !
En suite quand je met un bouchon d'essence direct dans le carbu la ça part !
MessageSujet: Re: Branchement pompe a essence !   Branchement pompe a essence ! - Page 2 Icon_minitimeSam 21 Déc - 18:23
Ouais, peut-être une daube dans la poutre! Vas y au cable épais ( frein de moto ) et passe sous la boite, puis sous te train avant! C'est chiant mais ça débloque les impuretés éventuelles!
MessageSujet: Re: Branchement pompe a essence !   Branchement pompe a essence ! - Page 2 Icon_minitimeSam 21 Déc - 18:24
Et tu as un filtre d'origine sous la caisse avant de rentrer dans la poutre, il est souvent pourri et jamais changé!
MessageSujet: Re: Branchement pompe a essence !   Branchement pompe a essence ! - Page 2 Icon_minitimeSam 21 Déc - 18:27
Ah ouias bon du cable j'ai un cable de frein de velo de 4 mètres ça devrait aller , après oui je vais tester la bouteille d'essence pas loin
Sachant que mon filtre a essence est branché coté roue arrière gauche et il est a peine bruni et il y a un juste un fond d'essence dedans
MessageSujet: Re: Branchement pompe a essence !   Branchement pompe a essence ! - Page 2 Icon_minitimeSam 21 Déc - 18:35
je te l'avais dit le coup de la bouteille  Branchement pompe a essence ! - Page 2 998756  mais pas con celui du câble  Branchement pompe a essence ! - Page 2 315149
MessageSujet: Re: Branchement pompe a essence !   Branchement pompe a essence ! - Page 2 Icon_minitimeSam 21 Déc - 19:06
Ouiap c'est vrai , de toutes façons j'ai pas bossé dessus depuis !
Mais le cable dans une durite rigide je vois pas trop comment on peut passer mais bon !
MessageSujet: Re: Branchement pompe a essence !   Branchement pompe a essence ! - Page 2 Icon_minitimeSam 21 Déc - 19:17
Tu le glisses comme dans une gaine!
MessageSujet: Re: Branchement pompe a essence !   Branchement pompe a essence ! - Page 2 Icon_minitimeSam 21 Déc - 19:18
comme celui de l'accélérateur  Branchement pompe a essence ! - Page 2 998756
MessageSujet: Re: Branchement pompe a essence !   Branchement pompe a essence ! - Page 2 Icon_minitimeSam 21 Déc - 20:30
Comme les câbles de frein à main ou de chauffage  lol!
MessageSujet: Re: Branchement pompe a essence !   Branchement pompe a essence ! - Page 2 Icon_minitimeDim 22 Déc - 1:34
Mouias bon j'essairai de toute manière !
MessageSujet: Re: Branchement pompe a essence !   Branchement pompe a essence ! - Page 2 Icon_minitimeDim 29 Déc - 20:07
Reprise des hostilités!
Donc j'ai branché une bouteille remplie d'essence directement reliée a la pompe a essence et hop ca démarre et ça tourne nickel !
Branchement pompe a essence ! - Page 2 2013-110
Bah oui quand tu es seul tu te la fait a la Miglouch' Garage hein  Branchement pompe a essence ! - Page 2 808202 Branchement pompe a essence ! - Page 2 808202
Donc j'ai fait tourner genre 10min , nickel , du coup je coupe et je tombe mon réservoir , je vous passe les détails pour vider le 3/4 avec une bouteille d'1,5L et un ruinage de dos au passage !
BREF ! une fois la durite de sous le réservoir débranchée ça coule plutôt bien , donc réservoir mis hors de cause !
Du coup j'ai passé un cable d'accélérateur cassé dans le rigide de la poutre , que j'ai reussi a enfoncer quasiment dans son intégralité...... On est forcé de penser que rien ne gêne dans la poutre donc !
Sauf que une fois le réservoir remonté , pompe a essence branchée comme il faut , je démarre et RIEN NADA NIENTE!!!!
Reste plus qu'a me dégotter un compresseur ! A moins que quelqu'un a une autre piste?
MessageSujet: Re: Branchement pompe a essence !   Branchement pompe a essence ! - Page 2 Icon_minitimeDim 29 Déc - 22:25
salut,
si ce n'est pas ta pompe ni la durite rigide,reste plus que les durites souples et/ou filtre a essence.
ou un exorciste  lol! .
HS: je vois que ton caoutchouc de pare choc est comme le mien,il se fait la malle tout le temps.
MessageSujet: Re: Branchement pompe a essence !   Branchement pompe a essence ! - Page 2 Icon_minitimeDim 29 Déc - 23:00
Ahh oauis ça tient jamais ces bouzes lol
