AFR Air Fuel Ratio / richesse quelques questions Icon_minitimepar cjcox Hier à 12:04
AFR Air Fuel Ratio / richesse quelques questions Icon_minitimepar Jul 13-02 Mar 19 Nov - 23:43
AFR Air Fuel Ratio / richesse quelques questions Icon_minitimepar Cox-34 Mar 19 Nov - 17:30
AFR Air Fuel Ratio / richesse quelques questions Icon_minitimepar weber1966 Lun 18 Nov - 21:16
AFR Air Fuel Ratio / richesse quelques questions Icon_minitimepar snake862006 Ven 15 Nov - 1:34
AFR Air Fuel Ratio / richesse quelques questions Icon_minitimepar Cox-34 Jeu 14 Nov - 18:49
AFR Air Fuel Ratio / richesse quelques questions Icon_minitimepar Cox-34 Jeu 14 Nov - 18:35
AFR Air Fuel Ratio / richesse quelques questions Icon_minitimepar SuperBat Mer 13 Nov - 20:43
AFR Air Fuel Ratio / richesse quelques questions Icon_minitimepar GUILLAUME Mer 13 Nov - 7:24
AFR Air Fuel Ratio / richesse quelques questions Icon_minitimepar Ju7 Mar 5 Nov - 0:51
AFR Air Fuel Ratio / richesse quelques questions Icon_minitimepar marcc Jeu 31 Oct - 15:45
AFR Air Fuel Ratio / richesse quelques questions Icon_minitimepar bertrand53 Mer 30 Oct - 11:40
AFR Air Fuel Ratio / richesse quelques questions Icon_minitimepar SV Lun 28 Oct - 18:16
AFR Air Fuel Ratio / richesse quelques questions Icon_minitimepar weber1966 Ven 18 Oct - 19:13
AFR Air Fuel Ratio / richesse quelques questions Icon_minitimepar weber1966 Mar 15 Oct - 19:13
AFR Air Fuel Ratio / richesse quelques questions Icon_minitimepar Peck Lun 14 Oct - 20:31
AFR Air Fuel Ratio / richesse quelques questions Icon_minitimepar cox911 Dim 13 Oct - 20:49
AFR Air Fuel Ratio / richesse quelques questions Icon_minitimepar SuperBat Sam 12 Oct - 18:46
AFR Air Fuel Ratio / richesse quelques questions Icon_minitimepar weber1966 Mar 8 Oct - 11:03
AFR Air Fuel Ratio / richesse quelques questions Icon_minitimepar jipi37 Sam 5 Oct - 18:29
AFR Air Fuel Ratio / richesse quelques questions Empty
MessageSujet: AFR Air Fuel Ratio / richesse quelques questions   AFR Air Fuel Ratio / richesse quelques questions Icon_minitimeJeu 24 Avr - 12:19
Je m’intéresse depuis quelques temps au système AFR avec sonde Lambda et indicateur (analyse du rapport air/essence, les fameux 14.7).
Au premier abord, ça ressemble pas mal à un truc qui permet de régler sa richesse avec précision et sans trop se louper.
MAIS ça reste une impression.
J'en viens donc à ma question, sur un moteur quasi stock (1600), ce système permet il d'avoir une plus-value par rapport au réglage classique à l'oreille?
Merci d'avance de vos réponses
mathieu
mathieu
Véhicules : 1303 04/1973
MessageSujet: Re: AFR Air Fuel Ratio / richesse quelques questions   AFR Air Fuel Ratio / richesse quelques questions Icon_minitimeJeu 24 Avr - 23:18
Perso je dirai non que ca n'apportera pas vraiment grand chose de plus, ou alors l'acheter à plusieurs pour pouvoir prendre un système nomade et régler d'autres voitures. Mais sur un moteur stock avec un peu (beaucoup) de patience, de tests etc... etc... il y a moyen de faire un trés bon réglage SANS.
Avec ces 200€ à ta place je ferai autre chose sur mon moteur. J'ai monté un Innovate LC1 pour mon moteur car je risque pas mal de soucis si je roule pauvre par exemple. Et que c'est mieux de voir le comportement en phase de boost.
Il y a un super article ICI : http://www.flat4ever.com/reglage-ultime-carbus-sonde-t52690.html Après... si tu es vraiment stock sans double carbus l’intérêt est encore moindre.
MessageSujet: Re: AFR Air Fuel Ratio / richesse quelques questions   AFR Air Fuel Ratio / richesse quelques questions Icon_minitimeJeu 24 Avr - 23:43
merci de ta réponse
j ai bien lu l article que tu cites mais ça va vraiment loin par rapport a mon niveau et mon projet
je pensais pouvoir facilement un réglage au top facilement donc souvent
mathieu
mathieu
MessageSujet: Re: AFR Air Fuel Ratio / richesse quelques questions   AFR Air Fuel Ratio / richesse quelques questions Icon_minitimeVen 25 Avr - 0:10
Un peu de patience suffira pour le réglage :D Les réglages de base bien faits (allumage, culbus, vis platiné, etc...), un petit coup de richesse et de ralenti et ca sera parfait.
MessageSujet: Re: AFR Air Fuel Ratio / richesse quelques questions   AFR Air Fuel Ratio / richesse quelques questions Icon_minitimeVen 25 Avr - 8:23
Pour 200 euros si j'étais toi j'acheterais plutôt par exemple un allumeur alfa33 et je ferais (faire?) des modifs sur un 34 pict en bon état style hiflow ou carbman. Ton argent sera bien mieux dépensé, les réglages bien plus simples et pérennes grâce à l'allumeur et le carbu t'apportera qqes cv bien agréables. Ou alors comme dit Mathieu achetez la sonde dans le cadre d'un club.
MessageSujet: Re: AFR Air Fuel Ratio / richesse quelques questions   AFR Air Fuel Ratio / richesse quelques questions Icon_minitimeVen 25 Avr - 8:58
j'ai investi dans ce matos, mais je l'ai fait en version nomade pour pouvoir paufiner plusieurs moteurs et comme dis mathieu avec une carburation d'origine c'est totalement inutile, mais ça m'a bien aidé pour différents montages "éxotiques" notamment pour la mise au point de mon injection
mais dans ton cas irvin te donne le meilleur conseil........
MessageSujet: Re: AFR Air Fuel Ratio / richesse quelques questions   AFR Air Fuel Ratio / richesse quelques questions Icon_minitimeVen 25 Avr - 11:10
OK OK
Merci de vos réponses Mathieu, Irvin, et Marqueleuleu
Je vais continuer à faire simple et efficace:
- carbu : il a 45 MK d'origine, pas de jeu, j'ai tout le matos pour la modif Carbman + pipe CBperf, montage sous peu
- allumage : j'ai un module et une bobine moderne + tête d'allumeur + doigt + fils de bougies + bougies neuves
- tiens, en parlant de tête, doigt d'allumeur les miens ont un peu charbonné au bout de 7/8 Mkm est ce normal ?
- Auriez vous une idée de leur durée de vies approximative ? idem pour les bougies, les changer tout les combien de km ?
MessageSujet: Re: AFR Air Fuel Ratio / richesse quelques questions   AFR Air Fuel Ratio / richesse quelques questions Icon_minitimeVen 25 Avr - 12:13
allumage => Par "module" tu entends un bricolage chinois qui remplace totalement les vis platinées ou juste un bête transistor qui évite d'avoir trop de courant au niveau des vis ?
Dans le premier cas garde le jusqu'à ce qu'il lâche, dans le second cas ça ne réglera malheureusement pas le problème de qualité récurrent des vis platinées (de m***e) qu'on trouve aujourd'hui, à savoir l'usure du pointeau qui frotte sur la came et dérègle tout en même pas 1000km.
Tête d'allumeur et doigt => jamais eu de soucis quelconques, un petit coup de papier à poncer fin de temps en temps pour nettoyer mais c'est plus psychologique qu'utile à mon avis.
fils de bougie => démarre ton moteur dans un endroit sombre et regarde si tu vois des petites étincelles bleues, si oui il est temps de les changer. Idem si tu te prends des châtaignes en les touchant mais c'est beaucoup plus désagréable comme test  lol! Un point souvent oublié, vérifie que tu as bien sur tes câbles les bouchons en caoutchouc qui s'enfilent dans les tôles autour des bougies, c'est dingue l'air qui peut partir par là.
changer les bougies => euhh pfff alors là... quand l'envie me prend, à savoir pas très souvent.
MessageSujet: Re: AFR Air Fuel Ratio / richesse quelques questions   AFR Air Fuel Ratio / richesse quelques questions Icon_minitimeVen 25 Avr - 12:58
Chinois je ne sais pas, c'est un kit Petronix avec un anneau à 4 aimants et un capteur. Vu que le seul souci que j'avais eu avec l’allumage, c'est le pointeau de came du rupteur qui a cassé (ça te dit quelque chose ....) j'ai pensé qu'en supprimant la partie "mécanique" je ne serai plus embête. C'est d'ailleurs le cas depuis quasiment 10 Mkm
Monté neufs tous les deux il y a environ 10 Mkm (pas des modèles transparents tuning), ça avait un peu charbonné, j'y ai mis in petit coup de papier à poncer comme toi.
Montés neufs il y a environ 10Mkm, rien à dire sauf un petit bémol sur l'ajustage des capuchons sur les tôles....
MMMouais, je contrôlerai quand même si elles ne sont pas grippées (c'est ma hantise) à la prochaine révision
Quoi qu'il en soit, merci de ta reponse
MessageSujet: Re: AFR Air Fuel Ratio / richesse quelques questions   AFR Air Fuel Ratio / richesse quelques questions Icon_minitimeVen 25 Avr - 15:27
pour que les bougies ne grippent pas suffit de graisser le filetage à la graisse HT
si je peux te donner un conseil au sujet du carbu, passe plutôt ta buse en 28 que de le débuser et centreur de jet, cela va d'une moins consommer, de deux sera plus agréable au roulage et de trois sera moins compliqué à réaliser à moins de connaitre un usineur capable
c'est du vécu et pas seulement du lut
pour l'allumeur perso j'y mettrai un tzh de popo ou d'alfa avec bobine de golf 3 qui sur différents montages ont donné les meilleurs résultats surtout niveau fiabilité
MessageSujet: Re: AFR Air Fuel Ratio / richesse quelques questions   AFR Air Fuel Ratio / richesse quelques questions Icon_minitimeVen 25 Avr - 16:14
ça c'est OK, c'est ce que je fais depuis toujours mais ce n'a pas été le cas du mécano précédent
OK OK mais au niveau des gicleurs, ralenti, pointeau, principal, tu mets quelles valeurs ?
La buse tu peux l'acheter ou ?
Pour moi, la différence entre le montage "busé 28" et "carbman", c'est que dans le deuxième cas, j'ai tout le matériel y compris l'usineur (moi même)
Là je me pencherai sur la truc plus tard, mon montage actuel me donnant satisfaction ce n'est pas une priorité
MessageSujet: Re: AFR Air Fuel Ratio / richesse quelques questions   AFR Air Fuel Ratio / richesse quelques questions Icon_minitimeVen 25 Avr - 16:23
J'ai cru voir que les nouveaux Hiflow ne sont plus débusés d'ailleurs mais busés en 29.
J'ai fait l'expérience de rebuser à l'arrache en 29 un carbu stock, sans centreur, et ça marchait pas trop mal, évidemment avec centreur ça ne peut être que mieux.
Sinon en teutonie ils vendent des "37 pict" ou des "39 pict" mais ça commence à avoir un coût certain et à mon avis pas trop adapté à un moteur stock.
