Erreur de branchement capsule double depression??? - Page 3 Icon_minitimepar fm7 Hier à 22:46
Erreur de branchement capsule double depression??? - Page 3 Icon_minitimepar 1715michel Hier à 11:30
Erreur de branchement capsule double depression??? - Page 3 Icon_minitimepar 1715michel Mer 26 Fév - 14:36
Erreur de branchement capsule double depression??? - Page 3 Icon_minitimepar buku Mar 25 Fév - 16:41
Erreur de branchement capsule double depression??? - Page 3 Icon_minitimepar buku Mar 25 Fév - 16:31
Erreur de branchement capsule double depression??? - Page 3 Icon_minitimepar bertrand53 Lun 24 Fév - 11:29
Erreur de branchement capsule double depression??? - Page 3 Icon_minitimepar Peanut Ven 21 Fév - 16:45
Erreur de branchement capsule double depression??? - Page 3 Icon_minitimepar coxforce Jeu 20 Fév - 15:42
Erreur de branchement capsule double depression??? - Page 3 Icon_minitimepar SuperBat Mer 19 Fév - 21:00
Erreur de branchement capsule double depression??? - Page 3 Icon_minitimepar SuperBat Mer 19 Fév - 20:59
Erreur de branchement capsule double depression??? - Page 3 Icon_minitimepar coxifly Jeu 13 Fév - 11:07
Erreur de branchement capsule double depression??? - Page 3 Icon_minitimepar coxifly Jeu 13 Fév - 10:01
Erreur de branchement capsule double depression??? - Page 3 Icon_minitimepar Liocox Mar 11 Fév - 17:07
Erreur de branchement capsule double depression??? - Page 3 Icon_minitimepar Liocox Lun 10 Fév - 22:29
Erreur de branchement capsule double depression??? - Page 3 Icon_minitimepar SuperBat Lun 10 Fév - 20:17
Erreur de branchement capsule double depression??? - Page 3 Icon_minitimepar weber1966 Lun 3 Fév - 20:31
Erreur de branchement capsule double depression??? - Page 3 Icon_minitimepar thomas83 Sam 1 Fév - 16:01
Erreur de branchement capsule double depression??? - Page 3 Icon_minitimepar rsengler Lun 27 Jan - 14:04
Erreur de branchement capsule double depression??? - Page 3 Icon_minitimepar ETHEVE Mar 21 Jan - 13:33
Erreur de branchement capsule double depression??? - Page 3 Icon_minitimepar le fous des cox Sam 18 Jan - 14:54
-94%
Chargeur sans fil – Samsung EP-P1100 Intérieur – ...
1.21 € 20.94 €
titicox59
titicox59
Véhicules : cox 1303 - 1973
Erreur de branchement capsule double depression??? - Page 3 Empty
MessageSujet: Re: Erreur de branchement capsule double depression???   Erreur de branchement capsule double depression??? - Page 3 Icon_minitimeMar 16 Sep - 14:33
Du coup je suis obligé d'aller au garage pour régler l'allumage car je n'ai pas de strombo?
Moi qui voulait faire mes réglages tout seul lol!
titicox59
titicox59
MessageSujet: Re: Erreur de branchement capsule double depression???   Erreur de branchement capsule double depression??? - Page 3 Icon_minitimeMar 16 Sep - 16:13
Voici les valeurs de contrôle du moteur AB trouvé sur le net:
Moteur AB
Carburateur PICT
Système d'allumage commandé par contacts
Contrôle visuel
● Flexibles de dépression raccordés
● Aération du carter-moteur branchée
● Le système d'échappement doit etre étanche
Conditions de contrôle et de réglage
● Flexible d'aération du carter-moteur débranché et posé de telle manière que seul de l'air frais puisse etre aspiré.
● Consommateurs électriques débranchés.
● Volet de départ complètement ouvert.
Nota
● Régler le régime de ralenti et la teneur en CO à leur valeur assignée respective en tournant alternativement les vis de réglage.
Valeurs de contrôle pour Service Antipollution
Température d'huile-moteur 80 °C mini
Régime de ralenti
BV mécanique 750 . . . 900tr/min
BV automatique, type 1
(automatique sélective) 850 . . . 1000tr/min
Point d'allumage
Allumeur avec capsule double
Valeur de contrôle 3 . . . 7° après PMH
Allumeur avec capsule simple
Flexible de dépression débranché
Valeur de contrôle 5,5 . . . 9,5° avant PMH
Teneur en CO au ralenti 2,0 . . . 4,0 % vol.
Angle de came 42 . . . 58°; 47 . . . 64 %
Bougies d'allumage
Désignations des fabricants Bosch W 7AC/W7AP, Beru 14-7 AU, Champion L-86 C
Ecartement des électrodes 0,6 . . . 0,8 mm
Couple de serrage 20 Nm
Périodicité de remplacement 20 000 km
Valeurs de contrôle et de réglage pour réparation
Température d'huile-moteur 60 °C mini
Régime de ralenti
BV mécanique 825±75tr/min
BV automatique, type 1 (automatique sélective) 925±75tr/min
Angle de came
Valeur d'usure 42 . . . 58°; 47 . . . 64 %
Valeur de réglage 47±3°; 53±3 %
Point d'allumage
Valeur de réglage 5±1° après PMH
Valeur de réglage 7,5±1° avant PMH
Teneur en CO 3,0±1,0 % vol.
Volumes de remplissage d'huile-moteur
Volume de remplissage d'huile-moteur 2,5 l
_________________________________________________________
titicox59
titicox59
MessageSujet: Re: Erreur de branchement capsule double depression???   Erreur de branchement capsule double depression??? - Page 3 Icon_minitimeMer 17 Sep - 10:48
Je pensais aller chez beetle shop à Nivelle (59) pour faire le réglage à la strombo.
Il demande je crois 25€ ce qui me parrait bien.
Qu'en pensez-vous?
