question debile mais pratique Icon_minitimepar gibolin78 Hier à 21:19
question debile mais pratique Icon_minitimepar rsengler Hier à 14:18
question debile mais pratique Icon_minitimepar le fous des cox Dim 1 Déc - 15:01
question debile mais pratique Icon_minitimepar weber1966 Sam 23 Nov - 16:41
question debile mais pratique Icon_minitimepar cjcox Mer 20 Nov - 12:04
question debile mais pratique Icon_minitimepar Jul 13-02 Mar 19 Nov - 23:43
question debile mais pratique Icon_minitimepar Cox-34 Mar 19 Nov - 17:30
question debile mais pratique Icon_minitimepar weber1966 Lun 18 Nov - 21:16
question debile mais pratique Icon_minitimepar Cox-34 Jeu 14 Nov - 18:49
question debile mais pratique Icon_minitimepar Cox-34 Jeu 14 Nov - 18:35
question debile mais pratique Icon_minitimepar SuperBat Mer 13 Nov - 20:43
question debile mais pratique Icon_minitimepar GUILLAUME Mer 13 Nov - 7:24
question debile mais pratique Icon_minitimepar Ju7 Mar 5 Nov - 0:51
question debile mais pratique Icon_minitimepar marcc Jeu 31 Oct - 15:45
question debile mais pratique Icon_minitimepar bertrand53 Mer 30 Oct - 11:40
question debile mais pratique Icon_minitimepar SV Lun 28 Oct - 18:16
question debile mais pratique Icon_minitimepar weber1966 Ven 18 Oct - 19:13
question debile mais pratique Icon_minitimepar weber1966 Mar 15 Oct - 19:13
question debile mais pratique Icon_minitimepar Peck Lun 14 Oct - 20:31
question debile mais pratique Icon_minitimepar cox911 Dim 13 Oct - 20:49
3cox4
3cox4
question debile mais pratique Empty
MessageSujet: question debile mais pratique   question debile mais pratique Icon_minitimeSam 5 Sep - 12:41
salut les gars quand vous lever l arriere de la caisse vous positionne ou les chandelle ???est ce que poser la caisse sur les truc qui serve au cric d origine est bon...???je lai poser la et ca a lair de se todre!!!!
MessageSujet: Re: question debile mais pratique   question debile mais pratique Icon_minitimeSam 5 Sep - 12:47
Non sur les articulations du train arrière pour moi ,les deux tubes rond sous la caisse,
3cox4
3cox4
MessageSujet: Re: question debile mais pratique   question debile mais pratique Icon_minitimeSam 5 Sep - 12:54
merci d accord je compte intervenir sur le train arriere refaire mes tambours et rabaisser la caisse est ce que ca n entravera pas mes travaux si je le pose ici...???
MessageSujet: Re: question debile mais pratique   question debile mais pratique Icon_minitimeSam 5 Sep - 12:59
J'ais moyennement confiance au support d'origine du coup je lève sur les articulations du train arrière et pour l'avant je lève sur le nez de chassis au niveau de l'articulation des de barre duuu train avant
MessageSujet: Re: question debile mais pratique   question debile mais pratique Icon_minitimeSam 5 Sep - 13:00
Ah la bonne question en effet
3cox4
3cox4
MessageSujet: Re: question debile mais pratique   question debile mais pratique Icon_minitimeSam 5 Sep - 13:01
merci lolo j ai poser la question avant d aller voir
3cox4
3cox4
MessageSujet: Re: question debile mais pratique   question debile mais pratique Icon_minitimeSam 5 Sep - 13:02
mais non c est bon merci bcp les tube que tu me dit sont fixe et l arbre passe dedans....(on dirait!!!! lol! lol! )merci
MessageSujet: Re: question debile mais pratique   question debile mais pratique Icon_minitimeDim 6 Sep - 18:45
tu peux positionner le cric au niveau des jonctions du châssis arrière et poser les chandelles au niveau des barres de torsions. les barres passent dedans alors ça ne t'empêcheras pas de les recranter. tu peux aussi positionner ton cric au bout de ton longeron, à l'aplomb de là où on met le cric d'origine, mais avec un petit morceau de poutre en bois pour répartir un peu la charge sur le longeron au lieu de la concentrer sur le point d'appui du cric
MessageSujet: Re: question debile mais pratique   question debile mais pratique Icon_minitimeDim 6 Sep - 20:15
Moi je pose aussi le cric sous la pointe en bout des lames et après je pose mes 2 chandelles sur les 2 cornes de chassis qui entourent la boite, une fois la voiture levée je reprend mon cric et je monte jusqu'a qu'il touche le carter moteur juste par sécurité
Et pour une seconde sécurité il te faut mettre une roue de secours a plat en dessous des longerons, et évidemment bloquer les roues avant !
question debile mais pratique Sign1010
question debile mais pratique Signat10
3cox4
3cox4
MessageSujet: Re: question debile mais pratique   question debile mais pratique Icon_minitimeLun 7 Sep - 0:09
ok merci les gars....
roue avant bloquee ....morceau de bois sur cric qui souleve les deux cornes qui entoure la boite.....chandelle pose sous les barres de torsions....
c est bon???
j espere jusqu a la ca tien en tous cas...!!!!je mettrer les roue pour la secu au cas ou( meme si je suis plus large qu une roue....!!! lol! lol!
MessageSujet: Re: question debile mais pratique   question debile mais pratique Icon_minitimeLun 7 Sep - 21:25
question debile mais pratique Wp_20116
je leve de chaque coté au niveau tube
je cale sur le bras au niveau fixation amortisseur
mais je garde mes deux point de lever de chaque coter aussi en securité
voir même en plus caler sous les roues arrieres
mich95
mich95
MessageSujet: Re: question debile mais pratique   question debile mais pratique Icon_minitimeLun 7 Sep - 21:39
je rajouterai que le calage, peut aussi se faire chandelles et cales de bois comme ci dessus (photo fufu), mais jamais chandelles et parpaings creux comme on le voit assez souvent..... question debile mais pratique 62039
MessageSujet: Re: question debile mais pratique   question debile mais pratique Icon_minitimeLun 7 Sep - 21:41
Ahhh oui !! Il suffit juste de mettre le cric sur un parpaing creux et lever la voiture pour voir ce que ça fait !
MessageSujet: Re: question debile mais pratique   question debile mais pratique Icon_minitimeLun 7 Sep - 22:24
Mais pour bien voir ce que ça fait il faut se mettre sous la voiture et attendre patiemment... question debile mais pratique 681905
mich95
mich95
MessageSujet: Re: question debile mais pratique   question debile mais pratique Icon_minitimeLun 7 Sep - 22:54
Je rajouterai qu'il faut faire monter quelques personnes dans l'auto pendant que vous contrôlez la solidité en dessous.......et en général le parpaing creux est très réactif.... lol!
MessageSujet: Re: question debile mais pratique   question debile mais pratique Icon_minitimeLun 7 Sep - 23:15
Tout ça évidemment fait dans une pente d'au moins 60% dans un coin bien paumé hein !
3cox4
3cox4
MessageSujet: Re: question debile mais pratique   question debile mais pratique Icon_minitimeMar 8 Sep - 0:47
merde j ais pas de parpain...!!!! lol! lol!
3cox4
3cox4
MessageSujet: Re: question debile mais pratique   question debile mais pratique Icon_minitimeJeu 26 Nov - 18:13
re salut les gars
et pour le devant vous soulever comment ...???a savoir que je vais revoir un peut tout le train avant ...donc ou positionner les chandelles???
MessageSujet: Re: question debile mais pratique   question debile mais pratique Icon_minitimeJeu 26 Nov - 18:55
perso je met les chandelles sous les fixations de barre stabilisatrice
comme ca
question debile mais pratique Lever_10
3cox4
3cox4
MessageSujet: Re: question debile mais pratique   question debile mais pratique Icon_minitimeJeu 26 Nov - 18:59
et tu peut sortir la barre apres...??
MessageSujet: Re: question debile mais pratique   question debile mais pratique Icon_minitimeJeu 26 Nov - 19:10
tu peut faire l inverse aussi
3cox4
3cox4
MessageSujet: Re: question debile mais pratique   question debile mais pratique Icon_minitimeJeu 26 Nov - 19:13
ah ok merci fufu j avais pas vu ton shema scuse....est ce que ca passe si je les pose juste a cote des fixcation..??ou c est plus fragile a cote... car je pense tout demonter pour reconfection complete...
MessageSujet: Re: question debile mais pratique   question debile mais pratique Icon_minitimeJeu 26 Nov - 19:38
j ai mis le pti schema apres
une bonne cale de bois
3cox4
3cox4
MessageSujet: Re: question debile mais pratique   question debile mais pratique Icon_minitimeJeu 26 Nov - 19:47
ok cool merci fufu
MessageSujet: Re: question debile mais pratique   question debile mais pratique Icon_minitimeJeu 26 Nov - 19:50
Tu peux mettre tes chandelles sous le chapeau de gendarme de chaque coté. Cela te laisse le train avant libre pour tavailler dessus.
