Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimepar cjcox Mer 20 Nov - 12:04
Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimepar Jul 13-02 Mar 19 Nov - 23:43
Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimepar Cox-34 Mar 19 Nov - 17:30
Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimepar weber1966 Lun 18 Nov - 21:16
Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimepar snake862006 Ven 15 Nov - 1:34
Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimepar Cox-34 Jeu 14 Nov - 18:49
Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimepar Cox-34 Jeu 14 Nov - 18:35
Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimepar SuperBat Mer 13 Nov - 20:43
Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimepar GUILLAUME Mer 13 Nov - 7:24
Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimepar Ju7 Mar 5 Nov - 0:51
Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimepar marcc Jeu 31 Oct - 15:45
Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimepar bertrand53 Mer 30 Oct - 11:40
Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimepar SV Lun 28 Oct - 18:16
Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimepar weber1966 Ven 18 Oct - 19:13
Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimepar weber1966 Mar 15 Oct - 19:13
Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimepar Peck Lun 14 Oct - 20:31
Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimepar cox911 Dim 13 Oct - 20:49
Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimepar SuperBat Sam 12 Oct - 18:46
Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimepar weber1966 Mar 8 Oct - 11:03
Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimepar jipi37 Sam 5 Oct - 18:29
pmthelord
pmthelord
Dacia Duster de 2009,
Kawa Z1000 de 2003.
Tubes réchauffage pipe, questions, éclaircissements - Page 2 Empty
MessageSujet: Re: Tubes réchauffage pipe, questions, éclaircissements   Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimeLun 18 Juil - 13:27
ok j'essaie de regarder ca :(
MessageSujet: Re: Tubes réchauffage pipe, questions, éclaircissements   Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimeLun 18 Juil - 15:35
Irvin a écrit:
Jette quand même un œil au jeu des culbuteurs côté 3/4 ça coûte rien, peut-être qu'ils sont trop serrés tout bêtement et les soupapes ferment trop tard voire pas du tout.
Après si les soupapes ferment bien et que tu as de l'étincelle il n'y a pas 36 solutions c'est que ça vient de l'essence. Si tu tentes de démarrer sans arrivée d'essence branchée sur le carbu ton moteur devrait vider les cuves avant de caler très rapidement, à ce moment là regarde si les deux sont vides ou si seule celle du 1/2 s'est vidée ce qui indiquerait que quelque-chose est bouché côté 3/4 mais j'y crois pas des masses.
Il n'y a qu'une seule cuve commune.
MessageSujet: Re: Tubes réchauffage pipe, questions, éclaircissements   Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimeLun 18 Juil - 16:38
Ah merde ! Bon ben raté, je connais pas du tout ces carbus...
Tu as une idée sinon ? Faire couler un peu d'essence par l'arrivée d'air du 3/4 voir si ça démarre ? Mais c'est un coup à se cramer méchamment les doigts...
pmthelord
pmthelord
Kawa Z1000 de 2003.
MessageSujet: Re: Tubes réchauffage pipe, questions, éclaircissements   Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimeLun 18 Juil - 20:06
j'y ai pensé aussi mais pas trop fan !
MessageSujet: Re: Tubes réchauffage pipe, questions, éclaircissements   Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimeLun 18 Juil - 20:16
Franchement je sais pas quoi te dire, autant je pense pas être mauvais en 3x Pict autant sur ces engins je suis sec...
pmthelord
pmthelord
Kawa Z1000 de 2003.
MessageSujet: Re: Tubes réchauffage pipe, questions, éclaircissements   Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimeMar 19 Juil - 1:46
si j'avais su ... j'aurais rien fait !!!!!! j'aurais economisé de la tune et des soucis ! pffff
Loïc
Véhicules : bay 73 westy
bay 74 westy
transporteur 83 westy
cox 1967
cox 1968
KG 1966
Juste pour citer les vw s
MessageSujet: Re: Tubes réchauffage pipe, questions, éclaircissements   Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimeMar 19 Juil - 10:22
Sur les IDF la cuve est commune aux 2 corps.
Il faut que la synchronisation soit faite sur les deux corps en ajustant avec les vis de by-pass > si un corps a plus de débit qu'un autre il nefait chauffer plus un côté que l'autre.
De même si la richesse (indépendante sur les deux corps) n'est pas correctement réglé sur l'un des corps, l'un des banc de cylindre peut ne pas fonctionner au ralenti.
A vérifier prise d'air du côté qui reste froid ainsi que le gicleur de ralenti à souffler avant de reprendre le réglage de synchro et richesse des 2 corps de carbus.
C'est simple à faire et ça prend en général 10 minutes.
pmthelord
pmthelord
Kawa Z1000 de 2003.
MessageSujet: Re: Tubes réchauffage pipe, questions, éclaircissements   Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimeMar 19 Juil - 10:34
j'essaie de m'y coller ce matin et je vous redis quoi ;)
pmthelord
pmthelord
Kawa Z1000 de 2003.
MessageSujet: Re: Tubes réchauffage pipe, questions, éclaircissements   Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimeMer 20 Juil - 10:44
alors demontage des cornes et reglages des culbuteurs faits.
rien n'a changé :(
pour info, lorsque j'ai retiré le manchon qui relie la pipe aux cornes, j'ai eu de l'essence qui a coulé.
Loïc
bay 74 westy
cox 1967
cox 1968
KG 1966
MessageSujet: Re: Tubes réchauffage pipe, questions, éclaircissements   Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimeMer 20 Juil - 14:24
En même temps, je ne pense pas que c'était la priorité!
le réglage culbu ok .. pourquoi pas... mais pourquoi démonter la pipe d'admission? il suffisait de contrôler une éventuelle prise d'air.
Je pense sincèrement que c'est juste un simple nettoyage/ réglage de carbu à faire..
As tu contacté la personne qui t'avait aidé pour le montage?
il faut vraiment vérifié les débits d'air de chaque corps et régler individuellement la richesse > pas d'histoire de réglage à 1 tour et demi sur les deux vis de richesse ou je ne sais quelle approximation qui n'a aucun sens dès que ce n'est pas juste pour effectuer le 1er démarrage moteur.
pmthelord
pmthelord
Kawa Z1000 de 2003.
MessageSujet: Re: Tubes réchauffage pipe, questions, éclaircissements   Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimeJeu 21 Juil - 0:03
pas fan d'asperger du liquide extremement inflammable près d'une source d'étincelles ... je préfère tourner sur 2 cylindres que d'avoir un tas de cendres lol
bref j'ai pas de prise d'air et côté gicleurs rien à signaler.
la personne avec qui on avait réglé le carbu ne se souvient pas de la config :(
pmthelord
pmthelord
Kawa Z1000 de 2003.
MessageSujet: Re: Tubes réchauffage pipe, questions, éclaircissements   Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimeJeu 21 Juil - 0:05
ah et à croire qu'en bretagne l'aide particuliere ou les pros ne courrent pas les rues car j'ai beau proposé de la tune personne ne bouge !
MessageSujet: Re: Tubes réchauffage pipe, questions, éclaircissements   Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimeJeu 21 Juil - 14:17
On est le 21 juillet tu sais... Regarde l'activité sur le forum tout le monde est parti ou sur le départ.
Le mieux à faire c'est de suivre ce que te disais Loïc, un dépressiomètre ça coûte pas cher voire tu peux t'en faire preter un.
pmthelord
pmthelord
Kawa Z1000 de 2003.
MessageSujet: Re: Tubes réchauffage pipe, questions, éclaircissements   Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimeJeu 21 Juil - 22:20
il y a le forum ... et les réseaux sociaux (plus simple de s'y connecter) ...
personne répond ! un "pro" m'a répondu, je lui ai demandé quand il pouvait passer (café ou bière offerte) et depuis aucune réponse ....
dépressiomètre c'est bien beau mais je n'ai aucune valeur ... faut que ca affiche quoi ? c'est bon quand c'est quelles valeurs ? c'est pas bon quand c'est quelles valeurs ? comment ça se met en branle ? etc ...
pmthelord
pmthelord
Kawa Z1000 de 2003.
MessageSujet: Re: Tubes réchauffage pipe, questions, éclaircissements   Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimeJeu 21 Juil - 22:25
MessageSujet: Re: Tubes réchauffage pipe, questions, éclaircissements   Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimeVen 22 Juil - 1:27
Loïc
bay 74 westy
cox 1967
cox 1968
KG 1966
MessageSujet: Re: Tubes réchauffage pipe, questions, éclaircissements   Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimeVen 22 Juil - 7:54
Il faut ce type d'appareil qui permet de comparer le volume d'air entre chaque corps.
La valeur absolue n'a pas d'importance c'est la comparaison qui importe
http://www.classic-store.com/product_info.php?products_id=4204.
Il faut toucher les by-pass si besoin en ouvrant celui du corps qui a la valeur la plus faible jusqu'à ce qu'elles soient identiques.
Il faut ensuite régler les vis de richesse en trouvant le point d'enrichissement optimum (juste la limite à laquelle le moteur tourne mieux en allant lentement du trop pauvre vers l'enrichissement en carburant) et en desserrant encore d'un quart à un demi tour supplémentaire à la fin.
il faut ensuite RE vérifier la synchronisation des 2 corps et retoucher si besoin.
pmthelord
pmthelord
Kawa Z1000 de 2003.
MessageSujet: Re: Tubes réchauffage pipe, questions, éclaircissements   Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimeVen 22 Juil - 10:29
ahhhh ! bah déjà on ne parlait pas de la meme chose ! moi j'etais parti sur les compressions
aux puits bougies !!!!! pour voir si compression est bonne.
pmthelord
pmthelord
Kawa Z1000 de 2003.
MessageSujet: Re: Tubes réchauffage pipe, questions, éclaircissements   Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimeVen 22 Juil - 10:40
pour loic, le souci c'est que je n'ai pas de cornets sur mon carbu. donc cet instrument ne "convient" pas car il tape sur les portes gicleurs au centre. on avait déjà tester chez un gars.
Loïc
bay 74 westy
cox 1967
cox 1968
KG 1966
MessageSujet: Re: Tubes réchauffage pipe, questions, éclaircissements   Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimeVen 22 Juil - 10:46
Je le fais tout le temps depuis des années avec ou sans cornets.... et de toute façon il n'y a pas le choix il faut mesurer..
tu peux de toute façon utiliser les prises de dépression prévues pour le réglage à la base du carbu avec un dépressiomètre électronique ou à colonne de mercure.
Loïc
bay 74 westy
cox 1967
cox 1968
KG 1966
MessageSujet: Re: Tubes réchauffage pipe, questions, éclaircissements   Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimeVen 22 Juil - 10:58
Afin d'illustrer mes propos.
sans cornets
Tubes réchauffage pipe, questions, éclaircissements - Page 2 160722101205373123
Loïc
bay 74 westy
cox 1967
cox 1968
KG 1966
MessageSujet: Re: Tubes réchauffage pipe, questions, éclaircissements   Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimeVen 22 Juil - 11:02
sur un vieux Weber IDF en utilisant les prises de dépression.
Ici par exemple avec un appareil "de poche" facile à transporter partout
Tubes réchauffage pipe, questions, éclaircissements - Page 2 16072210150157906
pmthelord
pmthelord
Kawa Z1000 de 2003.
MessageSujet: Re: Tubes réchauffage pipe, questions, éclaircissements   Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimeVen 22 Juil - 11:21
ok vu ! et du coup les compressions bougies je vérifie aussi ? quand je tourne a la main on sent bien qu'il y a en a
MessageSujet: Re: Tubes réchauffage pipe, questions, éclaircissements   Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimeVen 22 Juil - 11:50
Oublie les compressions des cylindres, synchronise tes corps en suivant le lien d'hier soir.
pmthelord
pmthelord
Kawa Z1000 de 2003.
MessageSujet: Re: Tubes réchauffage pipe, questions, éclaircissements   Tubes réchauffage pipe, questions, éclaircissements - Page 2 Icon_minitimeVen 22 Juil - 13:26
toi qui es à brest irvin tu veux pas passer a la maison ? :p
