cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimepar fm7 Hier à 22:46
cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimepar 1715michel Hier à 11:30
cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimepar 1715michel Mer 26 Fév - 14:36
cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimepar buku Mar 25 Fév - 16:41
cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimepar buku Mar 25 Fév - 16:31
cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimepar bertrand53 Lun 24 Fév - 11:29
cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimepar Peanut Ven 21 Fév - 16:45
cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimepar coxforce Jeu 20 Fév - 15:42
cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimepar SuperBat Mer 19 Fév - 21:00
cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimepar SuperBat Mer 19 Fév - 20:59
cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimepar coxifly Jeu 13 Fév - 11:07
cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimepar coxifly Jeu 13 Fév - 10:01
cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimepar Liocox Mar 11 Fév - 17:07
cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimepar Liocox Lun 10 Fév - 22:29
cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimepar SuperBat Lun 10 Fév - 20:17
cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimepar weber1966 Lun 3 Fév - 20:31
cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimepar thomas83 Sam 1 Fév - 16:01
cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimepar rsengler Lun 27 Jan - 14:04
cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimepar ETHEVE Mar 21 Jan - 13:33
cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimepar le fous des cox Sam 18 Jan - 14:54
-44%
Fauteuil gaming Arozzi TORRETTA noir
139.99 € 249.99 €
burgon
burgon
Cox cab 1302 - 1971
cheap speed  and 1303 power!!!!! - Page 4 Empty
MessageSujet: Re: cheap speed and 1303 power!!!!!   cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimeJeu 28 Déc - 2:19
Mais encore bravo pour tout ton boulot.
cheap speed
cheap speed
Véhicules : 1303
late panel 77
MessageSujet: Re: cheap speed and 1303 power!!!!!   cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimeJeu 28 Déc - 16:38
on ne s'improvise pas électronicien comme cela
aprés quatre essais de fabrication d'une résistance, avec fils résistif, cela ne marche pas, pas un sous de dépensé a part 4 fusibles.
je m'en retourne donc vers mes fournisseurs pour savoir si ils font "le rechauffeur électrique 12v pour pipe d'admission".
cheap speed
cheap speed
Véhicules : 1303
late panel 77
MessageSujet: Re: cheap speed and 1303 power!!!!!   cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimeJeu 28 Déc - 18:28
bad news:
cet aprés midi lavage d'auto aprés avoir fait un tour dans le chemin
je décide de rentrer la cox
une fois dans le garage une petite accel et là c le drame:
la courroie saute, explose mon hélice et défonce mon capot!!
je suis fort heureux!!
2017 se termine bien
cheap speed  and 1303 power!!!!! - Page 4 <a href=cheap speed  and 1303 power!!!!! - Page 4 Dscf6716" />
cheap speed  and 1303 power!!!!! - Page 4 <a href=cheap speed  and 1303 power!!!!! - Page 4 Dscf6714" />
les restes de l'hélice
cheap speed  and 1303 power!!!!! - Page 4 <a href=cheap speed  and 1303 power!!!!! - Page 4 Dscf6715" />
burgon
burgon
Cox cab 1302 - 1971
MessageSujet: Re: cheap speed and 1303 power!!!!!   cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimeJeu 28 Déc - 20:10
P.... !
Allez, 2018 pourra pas être pire.
cheap speed
cheap speed
Véhicules : 1303
late panel 77
MessageSujet: Re: cheap speed and 1303 power!!!!!   cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimeJeu 28 Déc - 21:16
ce soir le moral est plus bas et au vues des dégats c pas la joie a la maison.
je vais ressortir une hélice en alu du stock et voir si je peu fai quelque chose
j'ai bien une autre hélice en plug and play mais pas au bon diametre.
je vais encore mal dormir ce soir.j'était si prés de la fin, me voila avec un capot a refaire et là l'envie n'y est pas.
cheap speed
cheap speed
Véhicules : 1303
late panel 77
MessageSujet: Re: cheap speed and 1303 power!!!!!   cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimeSam 30 Déc - 13:17
travail sur la prise de côte pour adapter l'hélice en alu sur mon moyeux d'hélice plastique
fraisage de l'intérieur de l'hélice.
je vais démonter la couronne pour réduire les redresseurs de stator, donc repeinture a l'issue
dans la semaine prochaine je pense que j'aurais bien avancé
pour la poulie je part sur une poulie d'origine que j'ai commencé a modifier.
cheap speed
cheap speed
Véhicules : 1303
late panel 77
MessageSujet: Re: cheap speed and 1303 power!!!!!   cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimeSam 30 Déc - 13:25
arbeit!!arbeit!!!
voici mes deux hélices
cheap speed  and 1303 power!!!!! - Page 4 <a href=cheap speed  and 1303 power!!!!! - Page 4 Dscf6720" />
je vais priviliegier celle en alu
donc modif de la couronne qui n'est plus adaptée car faite pour celle en plastique
avant
cheap speed  and 1303 power!!!!! - Page 4 <a href=cheap speed  and 1303 power!!!!! - Page 4 Dscf6719" />
aprés:
cheap speed  and 1303 power!!!!! - Page 4 Dscf6718" />
hélice en situation:
cheap speed  and 1303 power!!!!! - Page 4 <a href=cheap speed  and 1303 power!!!!! - Page 4 Dscf6717" />
burgon
burgon
Cox cab 1302 - 1971
MessageSujet: Re: cheap speed and 1303 power!!!!!   cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimeSam 30 Déc - 15:12
Sois précis dans ton travail de rabiottage de ton hélice, il est facile de créer un déséquilibre ou un balourd en les reprenant? J'avais eu le problème sur ma jag.
cheap speed
cheap speed
Véhicules : 1303
late panel 77
MessageSujet: Re: cheap speed and 1303 power!!!!!   cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimeSam 30 Déc - 16:50
je travail avec des gabarits de façon a enlever la même quantité de matière.
après cette hélice est issu d'un vieux moulage dont certaines traces n'avaient pas étés suprimées.
les pales avaient aussi des épaisseurs miniment différentes.
je reprend tout cela en faisant attention.
cheap speed
cheap speed
Véhicules : 1303
late panel 77
MessageSujet: Re: cheap speed and 1303 power!!!!!   cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimeSam 30 Déc - 21:14
la couronne est de nouveau en place
cheap speed  and 1303 power!!!!! - Page 4 <a href=cheap speed  and 1303 power!!!!! - Page 4 Dscf6722" />
l'hélice a bien avancée ainsi que la poulie
j'ai tourné une pièce pour centrer l'hélice sur le moyeu et en mêmes temps la poulie
cheap speed  and 1303 power!!!!! - Page 4 <a href=cheap speed  and 1303 power!!!!! - Page 4 Dscf6721" />
cheap speed  and 1303 power!!!!! - Page 4 Dscf6724" />
cheap speed  and 1303 power!!!!! - Page 4 <a href=cheap speed  and 1303 power!!!!! - Page 4 Dscf6723" />
il me faudra boucher les trois plus gros trous a la soudure
puis voir la fixation de la poulie pour un démontage aisé de la demi flasque
l'idée est en tête, reste a appliquer
MessageSujet: Re: cheap speed and 1303 power!!!!!   cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimeSam 30 Déc - 22:43
Ah ce que je vois le moral et la motiv' sont revenus!😀
cheap speed
cheap speed
Véhicules : 1303
late panel 77
MessageSujet: Re: cheap speed and 1303 power!!!!!   cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimeDim 31 Déc - 20:59
aujourd'hui allègement des pièces en rotation
le moyeu :
cheap speed  and 1303 power!!!!! - Page 4 Dscf6726
l'hélice :
cheap speed  and 1303 power!!!!! - Page 4 Dscf6725
il reste encore du tournage sur le moyeu.
pour l'équilibrage ,je le ferais.
cheap speed
cheap speed
Véhicules : 1303
late panel 77
MessageSujet: Re: cheap speed and 1303 power!!!!!   cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimeVen 12 Jan - 23:04
la turbine porsche 964 est a la maison
maintenant au travail pour le montage et surtout rendre l'hélice solidaire de l'axe de l'alternateur pour la rotation
cheap speed
cheap speed
Véhicules : 1303
late panel 77
MessageSujet: Re: cheap speed and 1303 power!!!!!   cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimeDim 14 Jan - 20:51
bon je confirme dans le monde actuel pour 400 euros ,tu n'as plus rien.
la turbine est dans un état proche de l'ohio
l'alternateur est pourrit
tout va bien
j'ai tournée une piece pour la poulie.
le combo est démonté depuis hier
cheap speed  and 1303 power!!!!! - Page 4 <a href=cheap speed  and 1303 power!!!!! - Page 4 Dscf6728" />
cheap speed  and 1303 power!!!!! - Page 4 <a href=cheap speed  and 1303 power!!!!! - Page 4 Dscf6727" />
cheap speed  and 1303 power!!!!! - Page 4 <a href=cheap speed  and 1303 power!!!!! - Page 4 Dscf6729" />
cet après midi nettoyage.
tout est prêt pour le remontage au niveau de l'alternateur, il me resta trouver 4 vis en m3 pour la face avant, celles d'origine , j'ai été obligé de percer les têtes pour le démontage.
l'hélice et le stator sont dégraissés et prêts a peindre.
j'ai modifier mon support pour que la 964 monte, va falloir que je retouche la coiffe pour que cela monte correctement et cela sans la démonter.
cheap speed
cheap speed
Véhicules : 1303
late panel 77
MessageSujet: Re: cheap speed and 1303 power!!!!!   cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimeDim 28 Jan - 18:37
Après un silence radio me voila de retour
1:le support est modifier
2: la coiffe est découpée
3: l'hélice est peinte
4: l'alternateur est révisé et prêt a être monté dans son boitier de soufflerie
5: le boitier de soufflerie est nettoyer et prêt a peindre
6: le cône  est retouché pour que le combo monte.
7: une demie angle est fabriquée
cheap speed  and 1303 power!!!!! - Page 4 <a href=cheap speed  and 1303 power!!!!! - Page 4 Dscf6731" />
cheap speed  and 1303 power!!!!! - Page 4 Dscf6732" />
cheap speed  and 1303 power!!!!! - Page 4 <a href=cheap speed  and 1303 power!!!!! - Page 4 Dscf6730" />
MessageSujet: Re: cheap speed and 1303 power!!!!!   cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimeDim 28 Jan - 21:14
Pour tes réchauffeurs électriques va voir sur conrad ou rs ils en ont en 12v
Des films autocollants très bien faits
J en avais monté sur des pipes de t4 ça montais à 56/58 degrés
cheap speed
cheap speed
Véhicules : 1303
late panel 77
MessageSujet: Re: cheap speed and 1303 power!!!!!   cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimeDim 28 Jan - 22:48
oui tu as raison ,j'ai vu ces articles et sont en prévision d'achat
cheap speed
cheap speed
Véhicules : 1303
late panel 77
MessageSujet: Re: cheap speed and 1303 power!!!!!   cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimeDim 28 Jan - 22:58
cheap speed  and 1303 power!!!!! - Page 4 <a href=cheap speed  and 1303 power!!!!! - Page 4 Dscf6733" />
cheap speed  and 1303 power!!!!! - Page 4 <a href=cheap speed  and 1303 power!!!!! - Page 4 Dscf6734" />
MessageSujet: Re: cheap speed and 1303 power!!!!!   cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimeDim 28 Jan - 23:59
Toi t'es pas là pour amuser la galerie ! Des montages turbo beaucoup en parlent mais rares sont ceux qui vont au bout. Chapeau.
Par contre j'ai peut être raté un morceau mais tu as mis la config détaillée quelque part ?
cheap speed
cheap speed
Véhicules : 1303
late panel 77
MessageSujet: Re: cheap speed and 1303 power!!!!!   cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimeLun 29 Jan - 0:13
1600 kobelschmitt
culasses 043,guide changer , trois angles
vilo 69 chromoly l&g
bielles i beam chromoly l&g
aac engle 110
poussoirs scat
tiges culbu chromoly
ressort double l&g
coupelles gene berg
clavette chromoly
culbu 1.25 sur rampe rigide
pompe a huile meling 30 ,couvercle full flow berg
ventilation du bloc et prépa des conduit type hoover
vm empi chromoly ancienne génération
damper
turbo k14 golf
carbu 44hif passer en 44 hif metro turbo
échangeur air/air transformer en échangeur air /eau
tout l'ensemble et été equilibré par loïc charpentier engeneering
voila en gros
MessageSujet: Re: cheap speed and 1303 power!!!!!   cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimeLun 29 Jan - 0:27
Tu vises dans les 90 bourrins avec ça ? Voire plus ?
cheap speed
cheap speed
Véhicules : 1303
late panel 77
MessageSujet: Re: cheap speed and 1303 power!!!!!   cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimeLun 29 Jan - 0:51
a vrai dire je ne sais pas .
peut etre 120 a 130 mais seul un passage au banc pourrait le dire.
cheap speed
cheap speed
Véhicules : 1303
late panel 77
MessageSujet: Re: cheap speed and 1303 power!!!!!   cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimeLun 5 Fév - 20:21
support et sangle terminés
[img]cheap speed  and 1303 power!!!!! - Page 4 Dscf6735[/img]
[img]cheap speed  and 1303 power!!!!! - Page 4 Dscf6736[/img]
MessageSujet: Re: cheap speed and 1303 power!!!!!   cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimeMar 6 Fév - 21:26
cheap speed  and 1303 power!!!!! - Page 4 315149
cheap speed
cheap speed
Véhicules : 1303
late panel 77
MessageSujet: Re: cheap speed and 1303 power!!!!!   cheap speed  and 1303 power!!!!! - Page 4 Icon_minitimeMar 6 Fév - 21:42
[img]cheap speed  and 1303 power!!!!! - Page 4 Dscf6810[/img]
Page 4 sur 6Aller à la page : Précédent  1, 2, 3, 4, 5, 6  Suivant
