questions branchement faisceau neuf? Icon_minitimepar Totorino 29 Mer 25 Nov - 21:51
questions branchement faisceau neuf? Icon_minitimepar SuperBat Mar 24 Nov - 22:36
questions branchement faisceau neuf? Icon_minitimepar cheap speed Mar 24 Nov - 19:37
questions branchement faisceau neuf? Icon_minitimepar fiftyfree Mar 24 Nov - 10:05
questions branchement faisceau neuf? Icon_minitimepar fiftyfree Lun 23 Nov - 22:56
questions branchement faisceau neuf? Icon_minitimepar fiftyfree Dim 22 Nov - 21:32
questions branchement faisceau neuf? Icon_minitimepar fiftyfree Lun 16 Nov - 22:32
questions branchement faisceau neuf? Icon_minitimepar work1 Dim 15 Nov - 14:25
questions branchement faisceau neuf? Icon_minitimepar bill77 Dim 15 Nov - 13:59
questions branchement faisceau neuf? Icon_minitimepar Marc Diskus Ven 6 Nov - 14:16
questions branchement faisceau neuf? Icon_minitimepar Jul 13-02 Jeu 5 Nov - 0:46
questions branchement faisceau neuf? Icon_minitimepar Jul 13-02 Jeu 5 Nov - 0:43
questions branchement faisceau neuf? Icon_minitimepar Marc Diskus Lun 2 Nov - 2:22
questions branchement faisceau neuf? Icon_minitimepar Marc Diskus Ven 30 Oct - 15:43
questions branchement faisceau neuf? Icon_minitimepar 1303cab85 Mer 28 Oct - 17:57
questions branchement faisceau neuf? Icon_minitimepar Marc Diskus Lun 26 Oct - 20:10
questions branchement faisceau neuf? Icon_minitimepar Jul 13-02 Mar 20 Oct - 21:18
questions branchement faisceau neuf? Icon_minitimepar SuperBat Jeu 15 Oct - 19:28
questions branchement faisceau neuf? Icon_minitimepar didier60 Lun 12 Oct - 8:51
questions branchement faisceau neuf? Icon_minitimepar haguarde Dim 11 Oct - 11:51
Achetez une seconde manette DualSense pour la PS5
69.99 €
questions branchement faisceau neuf? Empty
MessageSujet: questions branchement faisceau neuf?   questions branchement faisceau neuf? Icon_minitimeLun 11 Mar - 18:02
Salut les hommes,
J'arrive sur la fin du branchement de faisceau made in USA sur ma 1303. Certaines choses me turlupine...pourriez vous m'éclairez!!!
donc, déjà, les schéma fournie ne sont pas complet, j'ai donc utilisé le liens si dessous mais qui viend d'une 1302... questions branchement faisceau neuf? 76925
http://www.vintagevw.org/images/1302-72a.jpg
1- je n'ai donc pas de ventil donc déjà, ca c'est fait, pas non plus de dégivrage.
2-Lors de la démonte de titine, je ne me souviens pas avoir vue de double témoin de circuit de freinage...y en at'il sur les 1303?(k2)
3- sur le compteur, en J (inverseur code à main)...ca ressemble à quoi ce bidule là!!!
4- auriez vous par hazard une photo de l'arrière de compteur de 1303 avec les références schéma parceque je doute du branchement de jauge?
Merci d'avance... questions branchement faisceau neuf? 39722
MessageSujet: Re: questions branchement faisceau neuf?   questions branchement faisceau neuf? Icon_minitimeLun 11 Mar - 18:16
[quote="Alex-76"]Salut les hommes,
Pour l'inverseur code a main J.
c'est le relais pour actionné les pleins phares.
tu a 5 fils. qui ce trouve sur boite fusible.
MessageSujet: Re: questions branchement faisceau neuf?   questions branchement faisceau neuf? Icon_minitimeLun 11 Mar - 18:17
[quote="COX02380"]
Alex-76 a écrit:
Salut les hommes,
MessageSujet: Re: questions branchement faisceau neuf?   questions branchement faisceau neuf? Icon_minitimeLun 11 Mar - 18:22
Tu parle du J sur compteur ?
tu fait pas une erreur?
Car le J inverseur code , ce trouve sur la boite fusible a coté du relais clignotant en 2 eme position.
et J que tu parle sur le compteur c'est J 6 stabilisateur du réservoir essence.
donc pas pareil.
MessageSujet: Re: questions branchement faisceau neuf?   questions branchement faisceau neuf? Icon_minitimeLun 11 Mar - 18:27
questions branchement faisceau neuf? Compte10
je sait pas si va te servir.
MessageSujet: Re: questions branchement faisceau neuf?   questions branchement faisceau neuf? Icon_minitimeLun 11 Mar - 18:29
A et H = +contact (noir)
J = jauge réservoir (marron)
B et K = éclairage de tableau de bord (gris/rouge)
D = phares (bleu/blanc)
F = huile (bleu/vert)
G = clignotants (j'ai oublié la couleur mais bleu/rouge d'après le schéma)
I = charge (bleu)
E = masse.
C et L =masse.
MessageSujet: Re: questions branchement faisceau neuf?   questions branchement faisceau neuf? Icon_minitimeLun 11 Mar - 18:50
questions branchement faisceau neuf? Boite_10
voila l'inverseur code a main .
MessageSujet: Re: questions branchement faisceau neuf?   questions branchement faisceau neuf? Icon_minitimeLun 11 Mar - 20:29
Ah!!!! Voila ce quil me fallait.... Un grand merci.... Donc le J dont je parlais, c est bien le J6 sur compteur. Il s augit donc du stabilisateur de jauge.... Il y a donc un + dessus et le 2nd est en H?
MessageSujet: Re: questions branchement faisceau neuf?   questions branchement faisceau neuf? Icon_minitimeLun 11 Mar - 21:31
Oui le j que tu parler derrière compteur c'est le J6. ( stabilisateur jauge essence).
pour branchement .
la lettre A et H + contact.
pour brancher le réservoir .
il y a des cox avec fils noir ou de fils jaune.
donc les 2 fils qui vient de ton réservoir , tu en 1 qui et écrit sur ta jauge G ce fils tu le branche la lettre J et l'autre a la fils de ton réservoir a la masse.
donc sur le plan d'avant avec les lettres il doit avoir 1 erreur
j = jauge réservoir ( fils marron) c'est soit le jaune ou un noir qui vient de ton reservoir.
le marron et une masse.
questions branchement faisceau neuf? Compte11
MessageSujet: Re: questions branchement faisceau neuf?   questions branchement faisceau neuf? Icon_minitimeLun 11 Mar - 21:39
questions branchement faisceau neuf? Compte12
MessageSujet: Re: questions branchement faisceau neuf?   questions branchement faisceau neuf? Icon_minitimeLun 11 Mar - 22:03
questions branchement faisceau neuf? Reserv11
MessageSujet: Re: questions branchement faisceau neuf?   questions branchement faisceau neuf? Icon_minitimeLun 11 Mar - 22:10
Nickel, branchement jauge faite!!!!! questions branchement faisceau neuf? 315149
MessageSujet: Re: questions branchement faisceau neuf?   questions branchement faisceau neuf? Icon_minitimeLun 11 Mar - 22:12
Sur ton stabilisateur tu bien mi le jaune?
car le marron et une masse.
MessageSujet: Re: questions branchement faisceau neuf?   questions branchement faisceau neuf? Icon_minitimeLun 11 Mar - 22:13
Et peut tu me dire si il y a un double témoin de freinage.... Parceque rien lors du démontage de ma titine.......
MessageSujet: Re: questions branchement faisceau neuf?   questions branchement faisceau neuf? Icon_minitimeLun 11 Mar - 22:15
mon cablagevest neuf... Ce sera donc un jaune rouge et marron pour la masse questions branchement faisceau neuf? 39722
MessageSujet: Re: questions branchement faisceau neuf?   questions branchement faisceau neuf? Icon_minitimeLun 11 Mar - 22:17
idem que toi ; j'avait qu'un seul témoin sur ma cox.
donc la remonte tout a neuf et donc je mais 2 témoin ( contacteur) .
MessageSujet: Re: questions branchement faisceau neuf?   questions branchement faisceau neuf? Icon_minitimeLun 11 Mar - 22:22
questions branchement faisceau neuf? Contac10
tu a combien de contacteur ?
Moi le shop qui ma vendu le maître cylindre ma dit qu'il fallait monté 2 contacteur et les monté en parallèle.
MessageSujet: Re: questions branchement faisceau neuf?   questions branchement faisceau neuf? Icon_minitimeLun 11 Mar - 22:26
Apres est ce que tu le voyant sur tableau de bord?
car montage différent .
montage simple sa allume les feux de stop quand tu freine.
et l'autre montage avec voyant sur tableau de bord , quand tu freine sa allume les feux de stop et aussi tu a plus de liquide frein ou pas assez sa s'allume aux tableau de bord.
MessageSujet: Re: questions branchement faisceau neuf?   questions branchement faisceau neuf? Icon_minitimeLun 11 Mar - 22:37
J ai 2 contacteurs.si je me trompe pas, ils sont déjà en parallèle sur mon faisceau neuf. Mais j ai rien demonté dans la voiture qui ressemblai a une loupiotte pour les freins.
MessageSujet: Re: questions branchement faisceau neuf?   questions branchement faisceau neuf? Icon_minitimeLun 11 Mar - 22:40
questions branchement faisceau neuf? Tablea10
questions branchement faisceau neuf? 1303_f11
MessageSujet: Re: questions branchement faisceau neuf?   questions branchement faisceau neuf? Icon_minitimeLun 11 Mar - 22:42
Ok.
les contacteur il y a 2 ou 3 broche?
MessageSujet: Re: questions branchement faisceau neuf?   questions branchement faisceau neuf? Icon_minitimeLun 11 Mar - 23:06
J'en ai 1 en 2 et 1 en trois broches....c est couillon ca . Si j ai bien compris, le 3 broche est utilise que si tu as une lampe temion... Chose que je n'ait pas donc il me faudrait 2 contacteurs 2 broches...
MessageSujet: Re: questions branchement faisceau neuf?   questions branchement faisceau neuf? Icon_minitimeLun 11 Mar - 23:22
MessageSujet: Re: questions branchement faisceau neuf?   questions branchement faisceau neuf? Icon_minitimeLun 11 Mar - 23:28
COX02380 a écrit:
https://www.1302-03only.com/t2127-contacteur-de-frein
ok, c'est donc bien ça... Je vais regarder pour mettre le témoin de tableau de bord en. Neuf sinon, je recommanderais un contacteur 2broches. Merci a toi.
MessageSujet: Re: questions branchement faisceau neuf?   questions branchement faisceau neuf? Icon_minitimeMar 12 Mar - 13:57
Salut .
sur certaine cox il y a qu'un seul contacteur , et un bouchon.
tu peut toujours branché le 2 broches.
et celui de 3 broches tu peut t'en servir comme bouchon.
